![](https://modelshipworld.com/uploads/set_resources_21/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
klaasvg
Posts posted by klaasvg
Ok thanks a lot again David, I will surely give that a try. Not sure whether I shall buy a Dremel sanding machine for this project only.... but good old sanding paper should do it too I suppose. It wll definately take some time and practice...
One more (hopefully last) question about the bulkheads. I understand that bulkheads 3 to 8 are malformed, I have the PDF file which shows the missing parts in red. In my project they are definately also malformed but they are in place already. Is it really crucial to corret this? I do have a (very old) fretsaw and can possibly get a pieve of triplex of the right thickness so if it is really an essential step I will give this a try too. I suppose a very strong superglue will be needed to put them in place with only the small sides touching each other!
Regards Klaas
Thanks again David for your quick reply! Indeed I an still in the early stage of the first layer of planking. I noticed already that the planks must be tailored to fit neatly when nearing the bow and stern. I do not yet have the best equipment but I gave it a first try using a stanley knife. I notived that the planks not only need to be tailored, but also are too think. Or maybe I need to file/sand the bulkheads of the bow and stern to make the planks lay a little deeper and also glue better? This will probably be a length operatino using only a file or some sand papter. Or can I use another tool for that?
For now I stopped after the first plank, I can probably still choose another approach if this is not working. On my photos you cna see that the plank does not really aligns smoothly with the rest of the structure. If you have anyt advice on this it is surelyy welcome, tomorrow I can eventually buy some extra tools if needed
Regards, Klaas
18 hours ago, drobinson02199 said:
If you mean the hull strips that you cut out, I think I used some CA medium and instant setting spray to help that process. Use a sharp set of scissors (good kitchen or office scissors are ideal) to cut them out.
Regards,
David
I think the hardest part is to make the hull planks fit by tailoring them in shape for the bow and stern. The manual mentions this very shortly on Photo Album Pages 10-11: 42)
"As the planking neas the bow there will be the requirement to taper the planks to allow them to lay alongside each other, this also applines to the stern"".
This is actually the part I got stuck some years ago, the planks are too thik to cut with a normal pair of scissors, is will probably be possible to cut them with a stanley knife but still you need to know exactly how to cut them. Did you use some big pair of scissors or another method? -
Thanks David for your reply. I actually meant the hull shelves, which are apparently difficult to apply. I am reading now through your log and see that there is apparetnyl missing some information in the manual. Also I read that some of the bulkheads were not correct, making the bow too shallow. This cannot be corrected anymore for me, apart from not having the materials for that so I hope it sill not be a show stopper... I will continue reading your posts and hope for some clarity sbout this subject!
On 9/25/2018 at 11:02 PM, puckotred said:
I have bought this kit and started building now about 10 years ago! Though a fan of the Titanic, I have not much experience with model building. I got stuck in this part, applying the bow strips. No idea how to do it and fearing I would forever destroy the model at this stage, I parked the project and the ship was slelved for many years.
Now I plan to continuw working on it but still need some advoce about putting the bow shelves on... Do you have any advice? I will insert an image of the current stage of my model! TIA
RMS Titanic 1912 by drobinson02199 - FINISHED - Amati - Scale 1:250
It is already a long time ago since my last post, again I postponed the project because of other priorities and the difficulties I encountered with the planking of the hull. I finally managed to apply the first planks, using water with some ammonia to soften the planks and bow them into position by first nailing them on the hull.
I still have a way to go but will show my progress up until now. I still have some issues, the small nails used to attach the planks need to be removed later and than can be difficult and damaged the planks. But because it its the first layer, I think this is no a big problem yet.
Also the planking on the stern site looks not so nice to me. I use some tools like sandpaper and an electric Dremel device but it still look a bit crude.
Also things can become more difficult as I am approaching the bottom section of the hull. So any comments are welcome!
Regards, Klaas
