ChiefClanker
Everything posted by ChiefClanker
  1. Last night I was thinking of making the decks convex upward just for that reason. At 1:96 the rise will be very small and was wondering it is really worth it. The convex does not have to be much, just enough. Also, the keel needs some work. The top and bottom of the keel are not exactly parallel, so the frames and deck beams will not be exactly correct. The keel will have to be modified or remade first. I need to think through how ensure the deck beams are at the exact same height. Doing a dry run is a good way to test this. Redrawing the frames to make each half mirror images of each other came out quite well. Most of the complete frames matched the new drawings. Drawing the deck beams and the through beams is still to be done. About a quarter of the frames need to be separated and re-glued. A Testors Wood Cement was used. I'm not happy with it. For one, it takes 12 hours dry and cure. And it is not very strong. In this case, that is good thing since a quarter of the frames need separating and re-glueing. Going forward I will use a waterproof Titebond II wood glue. As a result, glueing will commence only after a 'dry fit' is 100%. I plan to make my model seaworthy. It's a ship, for heavens sake! For the ballast I will use something called "Critter-clay". After forming it between the frames at on the bottom of the hull and letting it dry, it will be painted with a dull coat lacquer to make it waterproof and glued in place. Thank you for you advice, Steve.
  2. Right. It is better to correct sooner than later. It is much less 'expensive'! I copied the plans for the frames and redrew the plans by adding the mirror image. The next step is to add the deck beams to the drawings including the through beams. It seems best to do that now instead of trying to do so after the frames are attached to the keel. After that will be copying the frame and deck beam plans and the use the copies to reconstruct the frames and add the deck beams. When the drawings are complete, they will be added to my build log. Mark
  3. The encouragement to create a jig for attaching the frames to keel is painfully learned. I need to create a jig, or several jigs, for doing so. My first attempt did not turn out as expected. Details, details, details!! I may even remake the keel. The attached photo may show the frames did not line up quite the way they were supposed to. Today I will be making jigs for the frames and a jig for holding the keel and attaching the frames. This process may take longer than anticipated. But, then, maybe not.
  4. Allan, Thank you for the drawing of the HMS Director. It is a fascinating drawing. Just goes to show how much detail is 'missing' from many sets of ship plans from that era. The shipyards knew how to build ships and may not have needed such detailed plans as we are accustom to today. Mark
  5. Here are the frames glued together. The glue says to let it dry for 12 hours.
  6. This afternoon was spent making sure all my frame halves match their mirror pieces. All fit on the keel as they should. Next will be gluing the two halves together. Then it will be tracing the full frames and designing the cross beams. I need to decide on a jig for attaching the frames to the stem post, keel, and stern post.
  7. Steve, About a year ago I came across Time Team and Time Line. They are great shows indeed! Mark
  8. I marked the frame location on the keel. The jig looks very interesting! I may make one for larger projects and maybe for this one as well.
  9. Now that I set this up this far, I am rethinking my modeling clay jig & etc.
  10. Yes; I have an idea about how to do this. I'm going to read your build log first to see what comes after attaching the frames to make sure I set up attaching the frames properly. As a kid making plastic models, I used modeling clay as a 'third set of hands.' So as not to risk staining the wood with the modeling clay I will use a small piece of wax paper over the wood where the clay will be applied. I'll see how this works. May something more 'robust' will be needed.
  11. Here is the keel with where the frames will be attached. Maybe there is a better way to do this than writing on the keel. Before attaching each set of frames the markings and numbers will be erased.
  12. Today time was spent sanding the frames in pair to make them uniform between the two halves. This is performed on a Dremel Router Table with the Dremel tool rotating at a slow speed to reduce the chance of the sanding drum sending the pieces flying. Refer to the attached photo. I am very pleased with the results. Next I will mark on the keel (herein includes the stem post and the stern post, unless otherwise designated) where the frames are to be attached. After sanding with the Dremel tool, I sanded the edges with find sandpaper to rid the frames of the 'fuzz'. It was tedious work, but well worth it! I want to spend some time reading Louie da Fly's build log before proceeding too much further so a step of this portion of process is not missed.
  13. Using a scroll saw to cut small pieces can be touchy. Since I am very attached to my fingers, it seemed prudent to make it safer. I made a custom table top with a slot for the width of the blade. This made cutting the keel notches easier and safer. It has two coats of a clear and very liquid polyurethane. See the two attached photos. Soon the sanding of the keel and frames will be completed.
  14. Here are the frames cut and laid out. Today will be refining the frames and then sanding will commence.
  15. Some of the notches for the stem post, keel, and stern post need to be cut. Then, sanding the frames in pairs will commence. Hopefully, this will ensure the frames are the same shape & etc. Mark
  16. I may make a second model of the Winchelsea Nef to see if I can 'duplicate' my own efforts. It will also be to try a different method of making and attaching the frames to stem post, keel, and stern post. Also, I may try lapstrake planking instead of carvel planking.
  17. Yesterday I cut out the remaining frames. Today I will sand them and the stem post, keel, and stern post. Next, maybe tomorrow, will be laying out where the frames are fastened to the keel and begin attaching them.
  18. Angelwr, Your project is exceptionally cool!! Way to go. After working on a couple of my own projects, I will want to build a Sea of Galilee boat. It was in the back of my mind when planning my own projects. Warm regards, Mark
  19. The stem, keel, stern, and the frames are laid out on the basswood. I need another piece of basswood to get the remainder of the frames laid out. It may be hard to see the outlines, but they are there. The basswood is 1/8" thick. I will use 3/32" thick basswood for the planking. As one may guess, this will be a plank on frame model.
  20. A relative who has his bachelors degree in model making suggested getting the largest self-healing mat my workspace could handle. The craft store which has the largest variety of sizes and types had a two-pack on clearance. Each mat is 23 X 35 inches. The price was 70% off the regular retail price. I am very pleased to have had only that option on clearance. One mat is for the house and one is for the garage. At least for now that is the way it is.
  21. Yes, at last! Before cutting out the posts, keel, and frames, I made sure I numbered and label the parts appropriately. It is 6 below with a new blanket of snow and bright sunshine. With a warm garage, cutting out the posts, keel, and frames will be a comfortable endeavor.
  22. With Christmas and New Years over, I am commencing upon building my model ship. Louie da Fly provided the hull plans including the shape of the frames. After penciling in the remainder of the shape of the frames and the stem post, keel, and stern post, I cut out the shapes. See the attached photos. I will be using basswood. It is a popular wood for making models in these parts. There is plenty available in various sizes and shapes in hobby shops and hardware stores at a reasonable price. Next, I will cut out the stem post, keel, and stern post. After that, is cutting out the frames, two each. Before gluing the frames to the keel and posts, I will make a jig to keep the keel and posts upright while gluing. I named my nef, The Tyburn Treader.
