Hi All...and Happy New Year!
I've had a thickness sander for about two years now and it was immediately apparent there was some learning curve, as could be expected, to hold and feed the work material smoothly to get good results. And I'm pretty good and satisfied with it, to the point that I probably use it too much - can't resist a low removal pass after a joint glue-up for that flawless joinery look. I love the tool, and even though I also have the Byrnes disc sander and table saw, the thickness sander has surprised me time and time again with new capabilities that I wouldn't even have thought of otherwise.
My issue is that I run quite a bit of balsa and other soft woods, and sometimes in lengths far exceeding "normal" infeed/outfeed capacity. This is just reality for my work, I can't change it, and for the most part I do OK.
I'm wondering if others have tips, techniques, home-made adds-on, or secondary tool recommendations? Some ideas I'm considering:
Add an extension to the outfeed, possibly narrower to allow better access to the dial. Probably should add an infeed extension too.
Build an adjustable height helper, separate from the sander, to support material on the outfeed. Similar idea to the supports you see for cutting large plywood sheets on a tablesaw.
Add some kind of weighted device to the infeed side, like a roller, to prevent material from lifting into the sanding drum.
Add some kind of slotted device to the infeed side, where you could lower it down to just kiss the thickness of the material going in. Actually not really a slot, but a bar that would lower on top.
Buy a second thickness sander, of conventional woodworking type like a Jet 10-20. I do some regular woodworking anyway, but would be interested in how smoothly (or not!) a belt-driven sander might handle soft materials.
Thanks in advance.
