Everything posted by builder_Nick
I decided to add trunnels to the boat. The 1:16 scale seemed big enough to warrant the extra work. I used a draw plate and basswood (same material as the planks) to create the treenails. The size ended up a little big (1mm) but it was as small as I could go without the material falling apart as it was pulled through the plate.
The first phase of building the mold is pretty straightforward. I decided to attach it to a board where I first put down guidelines to help keep everything straight and in proper position. I glued it down by welding corners with hot glue. I figured that gave me an easier out if I needed to remove it from the board. Pictured also is the frame materials cut to length in prep for bending to the mold. Side note, I would have left the sheer tabs off until after fairing. They get in the way and are easily added later.
