Steve116
Members-
Everything posted by Steve116
Planking is complete. Difficult to bend basswood planks in 3 dimensions- I’m soaking the planks with boiling water and ammonia. There are several small gaps between planks. I painted several toothpicks the same color as the cockpit interior and glued them to the exterior hull to smooth the plank transitions
- 6 replies
- BluJacket Shipcrafters
- catboat
- 6 replies
- catboat
I just completed a week long rigging class that was conducted in Maine. This was v helpful and I was in the presence of 7 other more experienced modelers- I gained a lot of knowledge, confidence and inspiration to move forward ( and I bought a new model- a Herreshoff 12 1/2) I also picked up some tips to improve my techniques for painting the hull. As you might expect, this has created the need for more tools, and product, so I’m in the research and acquisition phase right now. Floquil paints are no longer, so I’m looking for a good substitute. Fine line tape to create a clean boot top on the hull, tools to clean up the portholes( perfect ellipses would be nice!) ( I settled on needle files and not a Dremel like device) And some Internet research to understand the nautical terms around a boat that are used in the Catboat’s build instructions
- 6 replies
- catboat
For Ben752 I too am looking for a better set of needle files. I have 3 Xacto files, but I need other cross section shapes for some detail work on basswood( model sailboat) My needs are not for roughing work. Is coarse a better choice? Thanks! Steve
It looks like Floquil hasn’t been around for awhile and recently that’s the case for Testors Model Master, too( since 2020?) I am finding some stock on the Internet, but not sure of age or the quality of this product.( I still have the Floquil paint bottles that are 14 yrs old- the Reefer white is completely dried) I’ve been advised not to mix water based acrylics w/ solvent based enamels( I’m going to consult Testors on Monday) It seems like a little more research is called for
Hi i have started to paint my Cape Cod Catboat. This is my first model. I have already painted the hull using Floquil product and hope to clean up the boot top using thin line tape above and below and using a spray clear coat enamel to “seal” the edges to prevent color bleed( an experienced modeler’s suggestion ) . This clear coat should be hi gloss to match the sheen of the hull paint Testor makes a hi gloss clear coat enamel BUT is currently unavailable- supply chain issues- has anyone used another hi gloss clear coat? The mast and gaff will be painted white. In order to be as authentic as possible, should this white match rhe white on the hull? Model overcoat- I have a friend that used a spray overcoat and was unhappy with the outcome - turned a satin finish flat. The model instructions recommend a satin polyurethane varnish. Miniwax offers that product in a can. What are modelers using- spray or brush? And if spray, the names of some brands, please Thank you! Steve
Rotary tool recommendations, preferences
Steve116 replied to Steve116's topic in Modeling tools and Workshop Equipment
Thank you everyone for your input. After considering all your comments, and weighing the risk of an irreversible ( I know, there are v few things that are irreversible) I opted to use my needle files. The portholes are not geometrically perfect ellipses or identical - maybe this will be part my model’s signature-but they’re not bad and I will take this as a learning experience -
Hi Bill. Thx for your input. Which Proxxon model are you using? -
Thanks, everyone. I’m learning that modelers share a passion and are ready to help. ALL your input is useful. one question for Jaager - what is HSS? -
Hi I recently joined Model Ship World and have completed the hull of a Blue Jacket kit #105- Cape Cod Cat boat. I'm a little stuck on building the single and double blocks and rigging and how they are installed. Any pictures of completed Catboats would be very helpful(esp the rigging details) and much appreciated. Cheers! Steve
- 165 replies
- cape cod catboat
- Finished
