Everything posted by cabrapente
ancre Le Fleuron by cabrapente - FINISHED
cabrapente replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
at the height of the lines, I will move away from the start of the angle, to the outside of the piece. the transfer to the wooden wedges, previously, I have seen totaling 90 degrees.- 332 replies
- le fleuron
- 64 gun
February 4: In these days of inactivity, I have given much thought and melon and think I've found the key when placing the ties of hawse. I take the point to all parts. (green line and orange)- 332 replies
- le fleuron
- 64 gun
December 23: in mid-November, I started coughing, I think for the sawdust powder. that cough, I broke the ribs and I've been on bed rest until I started rehabilitation today. and soon, when I have a little more mobility, we are acting up again. until then: Merry Christmas and happy holidays to all.- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
According to the drawing plane, on the edge of the frame, is the union between ligations, floors and genoles. the cuaderna28, is marked as a teacher. but it is between 29 and 30, which changes the meaning and what are the genoles face. or at least that's what I did. between frame 52 and 53, does the same, but face the floors. I realized that later but just to see if I misread the plans. a greeting cabrapente- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
looking at the plans, I see that the frame 52 is turn around and look at the floors. Is this correct or interpret it wrong? thanks cabrapente- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
I got two tables, with the profile of the central frames. there I put the copy of the frame to mount. powerful rapier, I placing and pasting each piece, starting from the center and respecting the silhouette. hit while the second frame, dried first. as the frames are smaller, cut them tables, so you can always put the clamps. a greeting cabrapente.- 332 replies
- le fleuron
- 64 gun
I've cut all the pieces of the frames. I'm starting to mount, but it is harder for me, because it takes two hands. good thing I have left is time hehe. regards cabrapente- 332 replies
- le fleuron
- 64 gun
I have a question. I think the sleepers are what I outlined in yellow. and I also think that the bath is drawn singing, with the stripped portion in the center line, which is the most I've drawn alta.y orange, bao serious tip, where support for the sleeper . Do I have reason? appreciate any explanation. thanks cabrapente- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
October 14: good ship will be in dry dock time. last Friday, the way to work, I fell off my bike, breaking four ribs, a collarbone and a beautiful pneumothorax. oh and some bruises. Well I'm back home and I'll settle for more photos and purchase information through internet. greetings to all.- 332 replies
- le fleuron
- 64 gun
.for now, the frame 1,2,3 and 62, are perfect I've hit the floors with genoles. now the keel accords- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
every day I feel like I'm getting better. I run less, so II mounted the stands. heights, I have taken of lines covered, but I'm not sure do things once.- 332 replies
- le fleuron
- 64 gun
the thicknesser is complaining. today I prepare the first frame, mounting it on the keel, to try to make the hawse. that in the plane cuts measures to engage in the keel, are perfect. I have not had to rectify anything.- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
I also agree the heights of the bond 9 and 10. is incomplete as if you were drawing. Does anyone guide me? thanks the first frame I start the keel- 332 replies
- le fleuron
- 64 gun
I have doubts. measures of the planes, not interpret the law. in the picture where you see the hawse from above, has drawn where it begins and ends each bond. I do not get it pass to the plane. vertically, much more open. specifying. not that thick to give each bond. how easy it would be, do wedges corresponding grades, forming a block of 90 degrees, cuaderana solaparlo the one hand and by the keel on the other, and desbastarlo. but I want to do it properly.- 332 replies
- le fleuron
- 64 gun
well today I finally reached the booklet fleuron him in Spanish. instead of changing them has been better send me a new one. planes, are far more detailed than the belle. but the monograph, are very brief. what I have seen, are basically, explanations of the plans, and measures of each piece. is not the expected step of mounting the rigging. I think because this model is not for novices. assumes that one knows riding gear. Nor any photos or bound in the booklet as the belle. frames, drawn whole were coming. I've saved from calcarlas. I photocopying 4 times each.- 332 replies
- le fleuron
- 64 gun
