cabrapente
Everything posted by cabrapente
  1. then I removed the hand drill, and put it in the electric. works perfect, and I can put half millimeter bits as ebony tapes are very irregular, but I could not get equal strips. the remnants, are many, but poorly usable. although the photos, they look good ...
  2. for if he forgot the triangular massif, which runs between the last rib and the stern ...
  3. the frame # 10, does not match bien.creo the fault has been on the rise, with respect to the keel. I have cut in half, and I have placed a new one.
  4. the frame # 10, does not match bien.creo the fault has been on the rise, with respect to the keel. I have cut in half, and I have placed a new one.
  5. the frame # 10, does not match bien.creo the fault has been on the rise, with respect to the keel. I have cut in half, and I have placed a new one.
  6. tapes as ebony, split when bent. the center as I did very fine work. but both thicker, I can not. Is it better to do them in another timber and then paint them? or did you do it for pieces? Thank you. I used the first frames that did not match to make the aft ligations
  7. I put the sleeping forecastle. tapes as ebony, split when bent. the center as I did very fine work. but both thicker, I can not. Is it better to do them in another timber and then paint them? or did you do it for pieces? Thank you.
  8. ligations of the hawse, I keep getting problems. I think not read the plans. and am getting a "tape" in the book calls Frolich,: moulurée lisse large. Well these slats to give rigidity.
  9. they do not know how, the notches of the keel, not well ... I cut all the pins, and I started from the teacher out, and with the squad, I have repositioned. I think it should do so first.
  10. Good. I caught one by one, measures the height of the frames, in the plane No. 7. and one by one the measures in ls frames planes 4 and 5. are not accurate. no frames, which are not drawn whole. and there is much left over at the top. my question is cut for your site. I will guide me along the line n º 7.If each leaf of each frame, I marked the heights. Anyone can tell me if it is correct? what rules, is the vertical line on the right, which is the height in the plane No. 7. so I checked all the leaves. Thank you.
  11. Good. if I've gone mad, I stopped short. but finally I came superimpose the last four frames. the lower boundary is a straight line along the top of the keel.
  12. I got a cherry plank. and I bought cinta.no saw is very good, but I've put PROXXON leaf and is luxury. and I'm trying to get decent strips of scraps of ebony. sawdust, coal seems.
  13. contrary to what I thought, I find it harder with the monograph, as before. I mean. before (to victory) if something did not fit, he added or took away asking me. Now, the first thing is to try to learn the names and take them to the plane. and once I find out, get a picture as faithful as possible to build the piece. but more I read, the more things I discover. every night I fall asleep reading and locating parts of the ship
  14. these other if they can utilizar.empiezo a new keel, which is not as I thought at first. the good is below ... if I'm not mistaken the rabbet did a useful thing I saw in a forum
  15. these frames, keel and do not coincide with the planes of the monograph.
