I’ve been scouring over photos of Endurance and have found a lot of errors with the kit. The front bulkhead should be open, the bits/cleats should be next to the windlass, the bridge from the Ritz to the cabin was three 2x12 boards laid down, there were no double vents next to the middle mast, the prop was two bladed, the half-moon prop cutout should be square, the planking on the aft cabin scales to about 1-2 mm, the planking on the Ritz scales to about 2 mm and planking on the front bulkhead scales to about 3 mm. Deck planks appear to be about 6 inches and scale to around 2-3 mm. The portholes appear to be about 12-14 inches so I’ll use some 4-5 mm brass tube for those. The cats heads should be much shorter and the aft railing has a wood handrail. The railings along the decks bend inwards and there are only two posts above the front bulkhead where the opening to the windlass is. The aft hatch entry is rounded and The deadeyes are oversized. There is some debate over doors but I’ve found some photos that make some look like sliding doors. More to come on that.
