Michael P
Everything posted by Michael P
  1. Very interesting, and many thanks. Can I say first that, as other have said, that a problem with Gutermann thread is that it’s very hard to get hold of all the colours that are on their charts. Now, Steel. The quote I gave is a bit puzzling, as it contrasts ‘cables’ with ‘hawser-laid ropes’. ‘Cables’ here probably does indeed mean anchor cables, but could be interpreted as ‘cable-laid’, which is not quite the same thing. There are a couple of other relevant quotes about tarring from Steel: ‘All cables and cordage to be tarred with good Stockholm tar, without mixture of any other, except about one-third part, which may be of Russia tar.’ And ‘bolt-rope is slack-laid, made white, and stoved and tarred by the sail-maker when used.’ He also explains that ‘Ropes, from 2 inches to the largest size, for running rigging, are hawser-laid’. Cable-laid rope, particularly if well-tarred, would have made no sense for running rigging, as it would have been too stiff to run through blocks. I was unaware till now of the full complexities of ‘cable laid’ and ‘hawser laid’. I see that there was some controversy about the 27 miles of rope supplied for the Master and Commander film, with suggestions that the right-handed lay was anachronistic, which it was not (Harland in Mariner’s Mirror, 2014, issue 1). A note by Harland (Mariner’s Mirror 2005, issue 3) explains the differences between British and American usage, cable-laid and hawser-laid apparently being synonymous in America, but not in Britain, where, somewhat confusingly, hawsers were cable-laid. Incidentally, I’ve used the online version of Steel at https://www.maritime.org/doc/steel/index.php, which is unexpurgated (but don’t expect to find it titillating). This is easier to read than the scan of the original edition at archive.org.
  2. A fascinating discussion. Goodness, Chuck, that’s impressive rope. I used to make model ships in the 1950’s, and found that cotton was hopeless, as if the atmosphere was at all damp, as it often was in Oxford, it stretched (much like old fashioned gut strings on tennis rackets, or those on the French crossbows at Crécy). What I used instead was terylene (a form of polyester, I think) thread, made by Sylko. There seems to be no problem about it lasting - it’s as good as it was over sixty years ago. I took to making models again in the last few years, and have been using Gutermann extra fine polyester thread. This seems good, but time will tell. I’ve not had real problems with unravelling; I use balsa cement to stiffen the ends of ropes, which makes it possible to thread deadeyes and blocks. It’s harder to make coils with it than the Sylko thread was. I’d not come across Gutermann Mara, which I think may be thicker than I need for small models. As for how to make ropes, fortunately, despite some family opposition, I kept over all these years a little machine I made from Meccano, so have not needed to buy a modern ropewalk, which in any case is currently unavailable from Cornwall Boats. Now, the colour of rigging. This appears to be somewhat controversial, with the fashion being for very pale, or even white, running rigging. The argument is presumably that this was not tarred. There’s an intriguing contrast, to judge by the photos on the web, between the black tarred rope used on HMS Trincomalee, and the pale ropes that feature on HMS Victory. Both are owned by the National Museum of the Royal Navy. Contemporary paintings are not much use, as any colour of rigging will appear dark against sky or sails. Models in the National Maritime Museum are difficult, as it’s often not clear from the photos on the web whether the rigging is original. I note that the model of HMS Ipswich (1730), which does have original rigging, looks to have it uniformly dark.Now, I read in Steel, writing in the 1790s, that ‘Yarn for cables requires more tar than for hawser-laid ropes. For running and standing rigging, the less tar the better, provided the thread is well covered.' This suggests that untarred rope was not used, and I’d have thought the right answer is to use very dark brown or even black for standing rigging, and a mid-brown for running rigging. Or perhaps just go with what seems best.
  3. It’s been too long since the last update, so here goes with another. Progress has been slow, largely because so much of the work is very fiddly, given the small scale of the model. A word about scale seems appropriate. As I said, I’ve adopted an unusual scale of 1:150 for this model: there’s no room in the house for anything much bigger. It may explain in part why what I have done is not as neat and beautiful in the photos as all the other models in this forum. My approach is that I want things to give the right impression, rather than trying for absolute accuracy. After all, the framing on Admiralty Board models was hardly to scale. The main problem is trying not to make the details oversize and clumsy. In my case, I’m aware that the deadeyes (which are bought) are bigger than they should be, but even Barrot de Gaillard allowed that it’s hard to have them accurately to scale. As is the case with many models, the deck planks at 2 mm. are a little wider than they should be, but cutting narrower ones would have been tedious and probably unsatisfactory. Various elements have proved tricky. The skylight was one, and it took a couple of goes. It is at least glazed, even if the glazing bars are not as neat as I’d really like. The chains were difficult, and in the end I compromised by twisting wire to hold the deadeyes (something which would have appalled R.C. Anderson, who condemned this practice), and then holding the wires in place with CA glue. Not a wonderful solution, but my attempts at proper links looked far too clumsy. It was much easier with my model of the mid-seventeenth century Winsby, which I fitted with plates not chains. I’ve done a bit more with the stern, but may return to it again. The carvings are a problem, of course. In the middle of the last century I used ‘plastic wood’, but I don’t think it would work at this scale. I could not get a decent result with Fimo, but Milliput proved less bad than anything else. In the late 1950s I probably used Humbrol gilt enamel for the carved work, which has lasted fine, but modern gilt paint intended for models seems rather less satisfactory. I’ve therefore used Liberon Gilt Cream, which is not easy to put on, but looks as if it will last. I’ve left the ship’s name, though I concede it may not have been there (see Gary’s comments earlier). Pocock, however, included Brunswick’s name in his painting of the Glorious First of June (https://www.rmg.co.uk/collections/objects/rmgc-object-11963), though this could be artistic licence, and Carr Laughton’s view was that ships did carry their names at this period. I’ve had problems with the quarterdeck, largely because the plans are not all that easy to interpret. Initially I followed the example of the kit models (excellent photos at https://www.modelships.de/verkaufte-modelle.htm), with two companion ways. This did seem odd, and it looks to me, however, as if the larger one is in fact a hatchway. It makes little sense to place steps just next to a capstan on the deck below. And the kits have two very small gratings, which I could not understand. One of the contemporary plans has one of these marked as ‘top tackle’, and I think that both are small hatches, fitted flush to the deck so as not to impede the guns when they are run back, and fitted with ringbolts. Some things were much more problematic to make than I expected. The skylight was fiendish, and still only just about satisfactory at the third attempt. Even the poop deck railing took much longer than I expected. There is no plan of Agamemnon to show such a railing, but there are sufficient other plans and models to show that they were frequently fitted. It will make rigging easier. I have not decided whether to fit the wire cranes and hammock nettings yet, for they will be fragile and could easily get broken when I get clumsy doing the rigging. I did, incidentally, go do far as to fit hammocks to a model of an American schooner of about 1820, which I constructed in the late 1950s, and I’ve included a photo for amusement. The hammocks, I recall, were cut from insulated copper wire, and have lasted fine. But I’ll not try that again. There’s still some tidying up, and the mizzen channels are still to be fitted among other things, but I should be on to the masts fairly soon, before Christmas gets in the way of work on Agamemnon.
  4. You will probably be thinking that I have given up on this model. Far from it, but it is taking an unconscionably long time. It is, of course, the small size that’s much of the problem, and I have had to make several efforts at some elements. I may yet have another go at the wheel, which was fiendish. Wire rims might look better, if I can do it. First time round for the quarterdeck guns they looked too large, and were difficult to make as the wood tended to split. So I went for card in the end. The breeching ropes are still to be fitted. Do I put more tackles in? Probably not. The skylight has taken a couple of goes, and is still unfinished, with no glazing so far. Anyway, the ship is slowly, slowly getting there, and will be done in time for the village show next year (last year’s model got best in class, not surprisingly as there was only the one entrant, and also got best in show for handicrafts). Can I ask if anyone has advice on a future problem? Most of the plans of this class of ship don’t show any rails on the poop deck, though that for Indefatigable (https://www.rmg.co.uk/collections/objects/rmgc-object-81744) has substantial ones, similar to the modern model of Agamemnon at https://julianstockwin.com/2017/10/10/agamemnon-the-darch-model/ . There is a simple block model of Indefatigable in the National Maritime Museum (https://www.rmg.co.uk/collections/objects/rmgc-object-66510 ) which looks as if it has a very low railing unlike any other I have seen. There’s also the possible alternative of a wire railing, similar to that which Longridge employed for his model of Victory, though that would not be easy at this scale. At present I’m thinking of ones like the plan of Indefatigable. Another question is how to do the gunport lids. Some models, such as the one of Mars in the NMM, show them raised all the way almost to the vertical, but I think a 45 degree angle is probably best. Just a word about tools. In the 1950’s I made much use of Gilette razor blades, snapped in half, but they were not exactly kind to my fingers, and I would not dare to use anything like that now. So it’s largely been a matter of my old faithful Stanley knife. Tweezers have been important, and a toenail clipper very useful. And a small archimedean hand drill has been essential. I read about rotary tools, and decided to try one out. It’s Chinese made, inexpensive, rechargeable, and surprisingly useful for tidying up details.
  5. Many thanks. Coincidentally, I got a large pot of white glue the other day. I used the floppiest thread I'd got, but even so it's really too stiff. I'll explain later how I make ropes, with a little machine made in the 1950s using Meccano. I am currently puzzled by the way in which the skid beams were supported by columns, which as far as I can see, would have got in the way of the capstan when it was turned.
  6. Well, it's been some time since I added anything, as progress has been slow. Never fear - this build log won't be an incomplete one. I don't want to hurry, as there's not that much room in the house for yet another ship model. I've worked on the guns, as the photo shows. It seemed right to fit them now, as once the gangways are in place, it would be more difficult. In my teenage years I used to make the guns by casting them from lead, in moulds made of plaster of paris. To melt the metal, I used a gas ring attached to the gas fire in my bedroom, and for the lead, found disused pipes in the cellar. Not exactly advisable in health and safety terms, but it was the late 1950s. For this model, I have simply carved the cannon from wood dowel, which looks ok at this scale. I'm certainly not up to using a 3d printer, even if I had one. The cannon are all Blomefields, with the ring on the cascabel to take the breeching rope. This makes rigging them a good deal simpler that it would have been with the Armstrong type, though I imagine that in reality ships in the late eighteenth century had a mix of the two types. The rings were not that easy, but I ended up making them from paper. Rigging canons is a problem at this scale. The carriages all have wire loops on the side to take the breeching ropes, which helps, but the various tackles would be a problem. I may fit training tackles in time, but the blocks would have to be very tiny, and having just the breeching ropes at least gives some impression of the way guns were rigged. The deck was straightforward, with the caulking done with a softish pencil. On this scale, the planks would have been about a foot wide, which is a bit too much, but they are at least a good deal narrower than is sometimes the case in models. They have had a coat of danish oil, while the gratings have had french polish. Next, I think, will be the gangways etc., and further work on the stern.
  7. Well, it's been a bit since I wrote another entry, and work proceeds slowly. I do now have a figurehead. Carving it out of wood was a total failure, as the material I had got was either too hard, or too soft. So Milliput was the answer. Then there was the question of painting. It's too small for me to paint accurately, and it seemed better to go for gilding, even if it's unlikely that any captain would have wanted to pay for this. The National Maritime Museum's model of Mars has a splendid white figurehead, but that looked much to bright on my model. It's not clear to me what contemporary practice was, and I suspect that there was limited consistency. As you can see from the photo, the forecastle now has gratings, belfry and bitts, all of which were tricky at this scale. It's all too easy to make such fittings too large, but it's obviously best to try to be as delicate as possible. Photos are difficult to get right - they always bring out the imperfections, and my only excuse is the small size of this model. Next problem is the guns. It seems much too soon to do them, but I don't see how I can do the beams and gangways, or indeed the quarterdeck, without them, as they would be fiendish to fit them later. That loop on Blomefield pattern guns won't be easy.
  8. There's an interesting couple of photos of a small gun carriage from the 1781 wreck of the Betsy in an American student's master's thesis on 'The Development of the Naval Gun Carriage . . .' (https://www.proquest.com/openview/7f87aba36437eef5e758c1624ba4e006/1?pq-origsite=gscholar&cbl=18750&diss=y ), pp. 91-2 . Though not that clear in the photo, one shows the two holes, which greatly puzzled the author of the thesis, who thought it might have been a manufacturing error, which it clearly was not. In the absence of a bibliography, I've not been able to find the original article detailing this find. Michael
  9. Just a quick reply with many thanks to Gary. Yes, blue was extraordinarily expensive. According to Vale in Mariner's Mirror (2020) Prussian blue cost 16s. a lb in 1785, as against an average of 4d. for white, red and yellow. Nor is blue mentioned in contemporary descriptions. Anyway, my beakhead will remain black with yellow detailing.
  10. That grating is 1/2 inch by 5/8 inch (or 11 mm by 17 mm). A 3d printer sounds very sophisticated - I can't manage anything much more than a Stanley knife. I was rather better at gratings in my youth. The photo shows a model I made in, I think, 1960. It was based on that of HMS Tartar (1734) in the National Maritime Museum, with some changes. My fingers must have been a good deal more nimble in those days.
  11. I've not said anything about the issue of whether or not the name should be painted on the stern, because I don't know the answer. Admiralty instructions are one thing, but were they always followed? Nicolas Pocock's picture of the Glorious First of June (1794) shows Brunswick's name clearly painted. And of course, though it's later, his picture of Nelson's flagships shows Victory with her name on the stern. As for practice before 1780, there is a plan of Sterling Castle (1775) in the National Maritime Museum showing the name in large letters on the stern.
  12. Well, I said I'd put something in about making gratings. I've never found it easy. In about 1955 I resolved the issue by buying some plastic ones (from Howes model shop in Oxford), which of course looked all wrong, even when painted. Recently I tried buying a gratings kit, but of course even the smallest scale that is produced was far too large for the scale I am using. Oversized gratings always look very wrong to me on a model. So, I am making them the way I have always done, though smaller. The first photo shows strips of wood with narrow square strips glued across. The strips are then cut into two, and are glued together one by one to make the gratings, as in the second photo. One advantage of doing it this way is that it is possible to curve the grating - look at photos of HMS Trincomalee and you can see the curvature. Of course the grain is not running the right way on the cross pieces, but that's not a real problem when they are so small. I'll probably finish the gratings off with a light stain and coats of French polish - they should certainly be darker than the deck. I am reluctant, however, to paint them, even if this was done at the time. And there will, of course, be a coaming round them. It will all take time to make all that will be needed.
  13. It's time for an update on my distinctly slow progress. The coppering of the hull is effectively complete, and worked quite well with the adhesive-backed strip. Goodness knows how it will last, but it does seem very sticky. I've been working on the bow. This was very fiddly, and required a good deal of experimentation. In the end, I found that it was best to make the rails from card rather than wood, as it was easier to get the bends right. The grating, which you can't see in the photo, was particularly tiresome. There is, of course, no figurehead yet. My first attempt, using Milliput, looked like a rather obese baby, but I will go on trying. The answer may be to carve it from wood, but we'll see. The style of the bow, with the yellow and black rails, does not really quite match the stern, and I will probably go back and redo that. According to Longridge in his The Anatomy of Nelson's Ships it was a convention that the beakhead bulkhead should be painted 'a rich ultramarine blue'. I've not done that, as I've not seen evidence for it in contemporary pictures, but I'd be delighted if anyone knows more about this, as it would be easy to make the change. There was not much blue in the recorded stocks of paint. The gratings are a problem. You can just see one on the forecastle deck, but there are a lot to go, and if the holes are too large, it all looks wrong. One problem is that the contracts I have seen from this period (there is one for Aquilon from 1786 in the NMM) state at the end that all gratings, ladders, gangways, bulkheads etc are to be painted. I've not seen any models, or indeed ships, with painted gratings, and am inclined to ignore this. I'll say something about how I make the gratings in another post. The model still looks a bit crude in the photo, but it's gradually getting neater.
  14. That's fascinating, Morgan. I'll certainly include a couple of huge carronades - at the scale I'm using they will in fact be tiny. 68 pounders look to have been rare, but apparently one survives from 1790, in the Royal Armouries at Leeds. Incidentally, there's an excellent account of carronades available at https://falkirklocalhistorysociety.files.wordpress.com/2019/03/object-9-carronade.pdf , but it's missed your 1796 reference. Michael
  15. Very many thanks -that's incredibly useful. There's no way I can attempt that frieze; I had decided that the ship should be as she was after 1796 when it was probably painted over. The model you refer to, which I did not know about, shows eight stern windows, which could well be right. I chose seven, following Indefatigable and a drawing of Stately, both in the same class, so I think I'll leave it as it is. I will clearly have to have a go at topless nymphs, but I'm not optimistic at this scale. Michael
  16. It’s about time I updated this log. I’ve been tackling the challenge that the stern presents, and the photo shows the state of play. There’s a good deal of tidying up to do, and I’ve not done anything about the gingerbread works yet. There’s much less room on the taffrail than is shown in photos of kit versions of this ship, and I doubt if I could make a reasonable effort at a topless nymph anyway. There’s no contemporary plan of the stern of Agamemnon that I can find, so I’ve followed that of HMS Indefatigable (before she was cut down and converted into a frigate), another in the same class. Any suggestions as to how best to do the carvings will be welcome. In the 1950’s I used plastic wood filler, but there seem to be much better products today. Paint colours are a problem. There are excellent discussions in Mariner’s Mirror vol 99 (2013) by Peter Goodwin, and in vol 106 by Brian Vale. They do not suggest that there was any gilding, but Nicholas Pocock’s painting of the Glorious First of June shows it on the stern of HMS Brunswick. He also showed gilded sterns in his picture of Nelson’s Flagships. I am undecided, but may gild the carvings if and when they are done. For now, I've just used a stronger yellow than that on the hull. The lettering is computer printed. It seems right to have white letters; this follows the latest work on Victory (see https://www.abyme.net/revue/victory/). Grey seems more appropriate than white for the window frames, to judge by Pocock’s paintings, but brown was another possibility. The coppering proceeds. I have seen much discussion of whether the copper should be weathered, and if so, what it should look like. To judge by HMS Trincomalee (preserved at Hartlepool), it would be very difficult to do effectively, and it seems best just to leave it as it is, and let it gradually lose its high sheen
  17. Build log duly started. Early days so far.
  18. That's incredibly helpful, Alan. I'd no idea that you could get the plans in proper detail. It's going to be particularly useful when it comes to the decks. So, very many thanks. Michael
  19. My present project is a model of Agamemnon. Why? Are there not enough models of this ship? Well, as a 64 gun ship, Agamemnon is not too big. At a very small scale of 1:150 there’s probably still room in the house. There’s even a book about her, by Anthony Deane, not that it contains much information about the design of the ship herself. And here are plans in the National Maritime Museum available online. There will, I think, be more differences between my model and the kit versions than just the scale. I should perhaps add that I am no photographer, but I’ll try my best. I’ve always built models on a bread-and-butter principle. That may horrify readers, but it was a standard late eighteenth-century method, and is advocated in what used to be (and in many ways still is) my bible, Barrot de Gaillard’s Construisez des modeles reduits de marine. What will probably appal even more is my use of balsa wood for the bread-and-butter core, but this does have advantages. It does not shrink or warp (as my surviving teenage models testify), and it’s remarkably easy to work. The photograph shows how depressingly crude the model is at this stage. The shot of my Sphinx possibly suggests that Agamemnon may come out all right in the end. Planking. It seems unnecessary to plank the whole of the hull, when all the underwater section will be coppered. But planking helps to smooth out any inconsistencies in the bread-and-butter hull. I have gone over the top to some extent, in that the wales are done in anchor-stock fashion. It may well not show once it’s painted, but since it can be done this way, why not? I did cheat, by cutting a single piece of wood in a zig-zag pattern. That way, it fits together neatly – almost too neatly. Coppering. The advice with a model on this scale is to avoid coppering. Nevertheless, I’m having a go. Many kit models have sticking-out pimples on their copper plates. These are presumably intended to indicate nails, but a look at a coppered ship, such as Trincomalee, suggests that the heads of the nails lay flat. Photos of City of Adelaide also show no sign of pimples or protuberant nails. The coppering of USS Constitution is new, but again, there are no pimples in the photographs I’ve seen. So, my model is to be coppered with 2 mm adhesive tape, made in China and bought through Ebay, with no attempt made to mark the nails. One problem is that the joins are very hard to see; I chose therefore, rather than using small pieces of tape, to mark the divisions by scribing them. It's important, of course, to make sure that the surface to be coppered is absolutely smooth. Being old-fashioned, I used French polish.
  20. As a teenager, I used to make model ships. One even won 3rd prize in a Model Engineer exhibition in London, though it looks very crude these days. Then a few years into retirement (now aged 80), I thought I’d try again, and so far have made models of HMS Sphinx, Winsby (later renamed Happy Return), RMS Britannia, and a late Elizabethan galleon based on the well-known Mathew Baker drawing. The present project is HMS Agamemnon. Not a kit (I've never made a kit model), and quite small at a scale of 1:150, as there's no room in the house for anything big. And the scale adds to the challenges. I'm attaching a photo of Winsby, which has a keel length of about 12 inches.
