Everything posted by Flyfisher
It has been a trying time for the past few weeks, as I attached the transom and quarter galleries to the model. The instructions are vague and I think I had a mind block on solutions. I had removed the machine-carved galleries at the beginning of the build,and now I had to replace them. I started with smoothing the edges to make sure it fit I intended to use as much of the original Britannia metal form as I could. I cut the lower deck portion with a saw and glued the metal seashell and railing to the piece. Unfortunately the deck assembly was too big and cut into the gunport. You can also see the disaster that I made with the windows. So it was necessary to remove the assembly and start over. This time I reached out to other BJ modelers, especially @g8rfan for some advice, as well as rereading the logs describing these parts. That meant trimming the deck, and reapplying the seashell and rails. So,the windows are funny looking, the trim looks out-of-scale, and the shape is shortened. I’m going to keep these as is for now, warts and all. If there are any tweaks you can suggest, please feel free to chime in. Semper Dienceps Jim
The kit-supplied deck is made in two pieces. I cut a template from the plans and discovered some surprises. My model is narrower than anticipated, no doubt because I didn’t exactly get the bulwarks thinned to the 5/32nd depth overall. They’re close, and only cost a few planks to get the fit right. I also cut the openings for the berth deck and masts. The only thing that bugs me is the obvious split down the centerline where the deck halves meet. I tried some obvious solutions, but it was of little benefit. If anyone has any suggestions, I’m all ears. All this happened about six weeks ago. Since then I have been trying to fabricate the quarter galleries and stern. Oh Boy! Has that been a headache. But, it’s almost finished so I should have a post soon. Semper Dienceps Jim
The gunports are all cut and painted. I discovered that my bulwark was not 5/32 throughout. It called for wider frames to cover and level each of the ports. I hope this doesn’t create issues when I add the cannon to the deck. I filled the gaps with putty and then added framing pieces to create a flush-ish surface. The waterway was also installed. It was time to plank the interior bulwark. Next steps are to paint the bulwark white and get the deck ready. I’m concerned that the line between the gundeck ceiling and spar deck will fall somewhere above the top part of the gunports and I’m going to need to peel off some decking to put the waterway in place. That’s where we stand now. I’m pretty sure I can get the deck in this week. I’m using the premade deck that is part of the kit. Questions and comments are always welcome. Semper Dienceps Jim
Hull Work This week I made good progress on the hull. The gunports on both Gundeck and Spardeck have been cut. I thought they were kinda ragged, so I lined all with 0.20 planking from a previous kit. During the process, I managed to crack the starboard side bulwark, which made that side weak. I tried to strengthen that area with epoxy. The epoxy helped, but I needed more stability, so I placed the transom supports at the stern. The combination of vertical and horizontal struts seemed to fix the wobble. It still scares me a bit that the bulwark can move. If anyone has any suggestions please feel free to share. And, as you see, I added the airports below the gundeck. The hull is just about ready to paint. After painting, I think it’s time to finish the rudder and the stem. Semper Diencep Jim
Well, I think it’s time for an update and I’m pleased to say that I’ve made some decent progress on the ship. (Knock on wood in case there’s any bad karma floating around.) I decided to copper and plank the hull before cutting out the gunports because they’re fragile and I’m clumsy. This allowed me to hold the hull in different positions while applying the copper tape. COPPERING THE HULL I had painted the hull below the waterline a shiny copper color to hide any blemishes in my application process. I cut the tape to mimic three plates and just butt-joined the ends. To create the pattern in the foil, I used a stamp from @g8rfan who sent me one of his spares. I like that it’s not too complicated, but still shows detail in the finish. PLANKING This step was pretty straightforward through most of the process. I bought additional planks from Bluejacket to cover the inside and outside of the bulwark. I gently bent the planks for the curve in the bow. At the stern, the planks needed more manipulation to follow the shape. Looking at the stern, I realized that the flare at the top of the sternpost was wrong. Too late now. CUTTING THE GUNPORTS One of my fears was cutting the gunports in the right spot, so they were the right height above the deck, the right size and that port and starboard lined up. I started by making a mirror-image of the side view plans, then taping those on each side. I used the edges of the waist to align my template. Then I used a 1mm drill on a dremel to score the outline on the template. My first attempt was pretty successful. The holes were in line and the pert side was 0.49” above the deck, while the starboard was 0.48”. I made a little jig to test each opening. Just a few scraps glued together, whose sides were 11/32” or as close as I could get it. To finish the holes, I would add slim wood strips or sand down high spots. And that’s where I am. Thanks for your interest. As usual, I would welcome any suggestions or advice moving forward. I plan to continue with the gundeck gunports, then the spar deck. Next steps are to attach the stem and paint. Semper Dienceps Jim
Thanks Greg I do think the people building the Constitution are awesome. I only count myself as the junior varsity to their skills however. Luckily I can steal, er…learn from their skills and apply them to my ship. There is almost a subset in this forum of Constitution makers. I know I read all of ‘em. I wouldn’t count on the instruction manual as a good guide. It rambles and makes suggestions, but you’re better off with the logs of other builders and looking at lots of pictures. But, I’m happy with this big chunk of wood. Just now planking the outside. Just remember to have fun. Jim
Thanks Jon. I’ve been following your build as well, because once we start planking and outfitting our ships, both the MS and Bluejacket versions face many similar challenges. I’m DM-ing with most of the other Bluejacket builders, although they are much farther along than I. They have saved my bacon a couple times already. Anyway, it’s nice to have several South Carolinians on the forum to share the torture.
Thanks @KurtH for the tip. I rigged a plumb bob and scored my stem line off that. After some aggressive digging and sanding I got the stem straight and the keel more or less back in line. I know the stem is too long; I’ll trim it later. With that fixed, I was ready (again) to start building a ship. First up was coppering the hull. I followed the same process that @g8rfan did and smoothed the hull with 400 grit, then applied two coats of gesso, followed by a shiny finish of copper. I only used one coat of copper because it’s just got to hide any boo-boos in the copper. I’ll be using copper tape along with the little device g8rfan sent me. Semper dienceps Jim
Stem Issues As I was measuring and marking the hull for planking and coppering, it seemed like the stem was off axis and leaning to port. So I rigged a plumb line and sure enough, I had attached it a few degrees off. Now the question becomes, what’s the best way to fix it, because I know this will cause many more problems down the road. It seems I both followed a wayward keel rabbet and kind of leaned the stem to get it in place. So I’m looking for advice about the best way to fix this without destroying the profile. My plan is to remove the stem and cut away the starboard area around the stem; rebuild the keel rabbet and re-shape the profile along both sides; then replace the stem. This looks like the line I need to follow. Any suggestions, tips, help or ideas would be greatly appreciated. Semper Dienceps (and one step back) Jim
Finally, the hull is complete. The exterior has been sanded smooth to 400 grit, and to my eye it is symmetrical. Shaping the inner bulwark has been a challenge. I began by trying to thin the wood to 5/32” overall, mindful that it should angle in about ⅜”. Everything seemed okay until I marked the height of the spar deck and gun deck. If the spar deck was the right height, the gun deck was too tall and vice versa. So that meant the height of the bulwark overall was too high. By about ⅛”-¼”. The other problem was the thickness varied from 1/16” to ⅜” and it was too wavy. Lots of adjustments needed. First I cut the ledge on the bow down to the right height (and you can see the variation in thickness.) Then I started thinning the bow with gouges, sandpaper and a dremel. This led to my next problem. The spar deck was TOO thin and cracked. So I glued it back, but the assembly was still fragile. So I started adding planks to bring the bow back to 5/32”. I thought this would help stabilize it. Hah! The original crack and the thin wood was just too much. I wound up cutting ¼” off the bow bulwark and replacing it with a “U” shaped piece of panel, then filing and sanding to fit (sorry, forgot to take a photo.) Anyway, the rest of the process was pretty straightforward: adding planks to fill the low spots and sanding to remove the high spots. And at last, the hull is finished. Normally, one would begin cutting gunports according to the meager instructions. I want to copper the hull because I’ll be turning it all cattywompus. (a technical term) and I don’t want to break the little fragile tabs. Semper Deinceps Jim
Finished Stern Fix Thanks @schoonerfor the encouragement. Little did I realize the bugaboos that come with a solid hull. It appears I have worked out my stern problem. I kept the stern lower counter so it matched the hull profile and made the stern post longer at the keel end It’s about 3/16” longer than the keel rabbet. I shaved the keel about 1/16” to match. I deliberately made the rudder a bit longer, so when it comes time to install it, I can trim it and still have room for the hardware. Hopefully none of this will come back to bite me down the road. Ever onward Jim
This may be a solution, although it might not be the right one. I don’t really want to go all the way back to a new hull as @KurtH has suggested, but if I restore the profile and affix the sternpost at that height, it almost matches the keel. Then I can keep the rudder the right length and attach all the gudgeons and pintles in the right spot So, do you think that makes sense? Thanks Jim PS. It was a good idea to ask @MrBlueJacket to weigh in with his thoughts. Thanks for the suggestion
Thanks to @KurtH, I was able to redo the lower part of the stern counter to both match the profile and cover the transom. But this created another set of issues When the profile is correct, the sternpost is too long by about ¼”. So, I cut a notch to make the sternpost fit. Much closer, but now I’m not sure this is the right fix. Should I leave the lower counter with the right profile and shorten the sternpost (and rudder) or file down the lower counter to its new position??? Or what??? I’m hoping someone with BJ experience can offer advice. Thank Jim
I have completed shaping the hull using the templates, but I ran into some trouble with the bow. I marked the bottom of the template (or the base level I was aiming for) with red washable marker. The templates showed a steep cut along the keel before flaring out at the bow. I stupidly didn’t look at any reference photos, just plowed ahead until I realized it was way off course and I needed to fill about 2 inches to restore the right profile. So, using leftover planks and shaping them as I went, I managed to fix my screw up There’s a sign over my bench that says “Pay Attention Dummy”. Upcoming: hours of sanding and filing and finishing Jim
Thanks KurtH and G8rfan for the heads up. I’m going to check both today. In the meantime, I have been carving the template stations with a ¼” gouge from the centerline to the stern. What strikes me most is that the depth of the cut is deeper on the starboard side than the port. Port Starboard Next up, I’m going to make an initial pass on the starboard side to smooth the hull and see what the profile looks like. Jim
Hello all, My name is Jim Martin coming to you from South Carolina and I’m tackling Bluejacket’s notoriously difficult Constitution. This will be my third model, having recently completed the HMS Beagle. I have been lurking on the logs of most other builders, both Bluejacket and MSW. I plan to shamelessly copy your best ideas giving credit wherever possible. I’m a slow builder so don’t post a lot, and my technique is pretty average. I hope you guys will bear with me and provide help as I join a bunch of others who all seem to be doing a good job. I have marked the hull, cut the templates and shaped the profile. Now to shape the hull. Finished Beagle The only pic of me at Nic’s place in Maine The first tool-to-wood action: removing the stern plug The only tip I can offer so far is that the instructions called for scoring a centerline along the keel rabbet. Since it was difficult to keep track of the line, I used a string fastened to the bow and transom and marked and scored it along that line
Cast Metal and Brass
Flyfisher replied to Flyfisher's topic in Metal Work, Soldering and Metal Fittings
Thanks. Sounds like glue is the most effective solution -
Alas,that’s what I’m doing now (gluing.)I’m building the Occre Beagle and this is some part that fits on the bow. I had a wild hair to solder the pieces because my glue jobs are sloppy. Hate to offend anyone, but I’m just experimenting
