MisterMeester
Everything posted by MisterMeester
  1. Did a complete dry fit of the Starboard side and pencil marked the hull for fit, accordingly. Sheet 1 for the Starboard side applied last night. Ended up with a slight misalignment with Plate #1 (indicated within the red circle). Not sure why that is as the rest of the sheet is aligned properly. I haven't completely researched the Stern Frame plating yet, but I'm hoping I'll be able to "fix" this when I get to that. The blue circle indicates plate edges protruding below the keel that I intend to sand down. I found this sheet a bit more of a challenge than the first Port sheet, in regard to getting the fit right as well as applying CA glue to the large gaps. Seems odd as I had 2 -4 glasses of wine in me for the first sheet. Perhaps different ergonomics that come with working on the opposite side is the explanation. But I digress. Thanks for looking. Suggestions are welcome. Cheers, Mark
  2. Yves and Evan, I still consider myself a rookie model builder, so thank you for the words of encouragement. It's means a lot. Yves, Interesting suggestion re: aluminum tape. It would be more malleable. Evan, When I did a Google search to find an answer to my above question(s) this very build log came up as one of the search results. Needless to say, I was quite pleased with that. So, yes....absolutely I hope that my documentation here will be of benefit to others who choose this aftermarket kit. Regarding sanding of the prominent plate overlaps, thank you for that suggestion. I will consider it, however, I'm not sure my skill level won't botch it. Some sanding I am very much considering is the plate edges in the after part of Sheets 1 (both sides) as there are quite obvious protrusions below the keel. Cheers, Mark
  3. Sheet 5 done. Time to begin attaching the sheets to the hull. Instructions for doing so.... The instructions are quite clear and specific regarding the fit of the sheets transversely. However, they are not clear and specific regarding where to start with Sheet 1 longitudinally. “Plate 1 must line up with the kit plates at the rear.” It is unclear what, exactly, that means. Dry Fit #1 This is where I started with Sheet 1, Port Side, taking into account the vertical width of Plate #1. This positioning ended up being wrong. Marking for the 1mm overlap for Sheet 2. Port Sheet 1 dry fit, showing transverse alignment. Port Sheet 2 dry fit, showing transverse alignment. Port Sheet 3 dry fit, showing transverse alignment. Port Sheets 2 and 3 dry fit, showing transverse misalignment inboard. Something isn’t right. I continued the first dry fit with Sheets 4 and 5, but neglected to take pictures of this. The overlap of Sheet 5 onto Sheet 4 was way too much. From memory it appeared to me to be ~10+mm overlap, rather than 1mm. Something was clearly not right. It was quite obvious that everything needed to be shifted aft. But how far aft? Where is Sheet 1 supposed to start? Off to YouTube to research an answer. Dry Fit #2 – I found little information on YouTube regarding this aftermarket kit, and nothing that specifically addressed my question. However, in one video there where a few seconds that appeared to show the aft edge of Plate #1 of Sheet #1 as far aft as the stern frame. This was my starting point for the second dry fit. Unfortunately, I neglected to take a picture of this as well. However, this starting point is indicated in an upcoming third dry fit photo. The following two pictures show longitudinal misalignment still present. Everything now needs to be shifted forward. The middle of Sheet 4. The step from Plate 170 to Plate 178 is supposed to align with the kit plates. This isn’t mentioned in the instructions, but it’s obvious. Longitudinal misalignment of Sheet 5 indicated here. Again, proper longitudinal alignment isn’t mentioned in the instructions regarding this sheet either, but it’s obvious. By measurement, everything needs to be shifted 2.5mm forward. Dry Fit #3 Sheet 1 moved 2.5mm forward. Red arrow indicates the pencil mark showing the starting point of the second dry fitting. Sheet 4 aligned longitudinally. Sheet 5 aligned longitudinally. As well, the inboard misalignment mentioned earlier, of Sheet 2 with Sheet 3, is no longer there. Okay. Appears I got it. Time to glue. I chose to go with the E6000+ option. In another YouTube video, the modeler used a Q-Tip to spread the glue on the underside of the sheets. I did the same, but I would not recommend that method as the cotton spreads out from the tip and, at one point, a chunk of cotton came off. For the subsequent sheets, I plan on using a cheap bristle brush. I managed to spread the glue thin enough to avoid the potential issue of glue coming up through gaps at the plate seams. Dealing with large gaps along the Turn of the Bilge…… At first I attempted using Tamiya Extra Thin Cement to deal with the large gaps, as per instructions, however, as one has to hold pressure on the styrene during the curing, it became quickly apparent that doing all gaps by this method was going to take way too long as the curing time is relatively slow. Therefore, I switched to CA glue and applied it with a Glue Looper. Another aspect I learned from one of the YouTube videos is that the protrusion of Plate #1 is actually to be folded over and glued down to the keel. This is not indicated in the instructions. I'm still undecided on the position of the aft edge of Plate #1. I may choose to trim that when I tackle the plating work around the Stern Frame. Port Sheet 1 completed. I figure it would be best to do Starboard side Sheet 1 next, as opposed to the rest of the Port side. In my mind that approach would ensure uniform alignment of both sides on the longitudinal axis. Thanks for looking. Suggestions are welcome. Cheers, Mark
  4. Another labelling mistake from the manufacturer. Plates 203 and 204 of Sheet 5 are mislabeled on the styrene sheet. The template sheet is correct. Seems with each aftermarket kit I've bought and either looked at or begun working with, so far there is at least one issue. Again, not a big deal here, but for a detailed person who expects better, it's a tad annoying. Further, as per instructions, the plates are to be laid in the numbered order. Took a minute or two to figure this anomaly out. Buyer beware when it comes to aftermarket kits, in my opinion. I might just send a short email to the supplier of this kit to give them a heads up on this. Thanks for looking. Cheers, Mark
  5. Started Sheet 5 ...... .....as per instructions, noting that some of the forward most plates are not symmetrical to each side.... ....and it didn't take long to discover that these asymmetrical plates are labelled incorrectly. Not a big deal, and I suppose it's irrelevant, if one is paying attention and cuts, then applies, each plate as one goes. Further, it appears that this sheet does not have as many plates as the previous four. Should be able to get this sheet done in less than a week. Thanks for looking. Cheers, Mark
  6. Sheet 4 done. One sheet left. It takes me about 1 hour and 20 minutes to do one row of eight plates. ~ 16 hours for an entire sheet. Hoping to have Sheet 5 done in a week. Thanks for looking. Cheers, Mark
  7. Minor imperfection on Sheet 4. Port plate #146 not entirely cut through. Not a big deal. Cheers, Mark
  8. Sheet 2 done, a few months ago. Golf season over, Scale Modeling season commenced. Sheet 3 completed today. Two more sheets to go before applying to the hull. Thanks for looking and cheers, Mark
  9. Sheet 1 done. Starting Sheet #2 soon. One recently learned disadvantage to being on a blood thinner as a result of an angioplasty is that back issues are not immune to easily being rectified by a chiropractor. As it is, I have suffered a back ailment (not the first time), that, because of my recent stent implants, cannot be rectified in a traditional "back crack" chiropractor way until said implants have "healed" (6-12 months). A disappointing aspect of this (the back ailment) is I can't swing a golf club without resultant pain and can't get "fixed" by my chiropractor without "back cracking" until said stent healing is complete. I've been worse off before, but not in this scenario, and hoping that this setback can be rectified with modified chiro appointments as well as self care (read: annoying exercises) at home. Point being, I will initially, and maybe beyond, have more time on my hands than expected to continue work on this project this summer. Hoping not, though. Thanks for looking. Suggestions are welcome. Cheers, Mark
  10. Working the underhull plating kit from Woody's Modelworks (aka Maritime Models) has begun. The idea here is to build the plating in five sections, setting aside each section as it's completed, and then glue the sections to the hull en masse. The seller states (in an email reply) that the thickness of the styrene is 0.20mm. I don't dispute that as it appears, in a side by side comparison to the .005" (0.13mm) styrene I used for the stern plating, to be slightly thicker. As with the stern plates worked, there is a "lip" on each of these plates that I deem necessary to sand down. And so it begins. I think this will be fairly easy, just tedious and time consuming. It's going to take awhile. Thanks for looking. Suggestions are welcome. Cheers, Mark
  11. Phil, Very good points. Thanks. Never considered a ruler might be inaccurate. I do not have calipers. The ruler I used is a cheapo bought at a drug store. Anyway, it all worked out. If I'm ever in need of this kind of accuracy again, which I suppose is likely, I will definitely take your points into consideration. Me thinks a Staedtler ruler would be accurate. Cheers, Mark
  12. Stern plating completed. As mentioned earlier, I decided to go with .005" thick styrene. So, essentially, I paid $70 CDN for a template and instructions, as, in the end, I did not actually use Midwest Model Shop's .010" styrene kit. . .005" x 200 = 1". According to “Titanic: The Ship Magnificent” (Vol 1, pg 145), the ship's shell plating was various sizes, but 1" thick at the most. .010" is not to scale. Here's a pic of the layout guide scribed onto the hull.... Here's the .005" styrene traced out using the .010" aftermarket kit's sheet.... I used the negative spaces of the original kit sheet. Most of the traced plates on the .005" sheet were smaller than needed. A lot of measuring was required, for most plates, to cut them a tad larger than traced and get them close to right. I added 1mm to the width of each of plates 1 thru 6, indicated in this picture, to bring the whole sequence 6mm further forward and thus a more accurate representation, as indicated within the blue circles. Applied to the Stbd side as well. Some pics of the final result. Immaculate? No. "Museum Quality"? No. But I'm pretty happy with it. The .010" styrene was just too thick and resulted in many gaps and protrusions along the rub rails. The .005" styrene, although maybe still not perfect, results in a cleaner finish, in my opinion. Very happy that the aftermarket kit plate seams now line up with the Trumpeter kit plate seams, as indicated here..... So far so good, right? Not quite. An unavoidable inaccuracy exists with this application. I mentioned a reference to it earlier in this build log and it didn't go away despite applying the correct scale layout guide. To repeat....the top row of portholes on Trumpeter's representation are not high enough. This results in a conflict with the location of portholes on a couple of the aftermarket kit's plates. Here's a pic, before trying to explain it in words..... Contrary to Trumpeter's representation, the line of portholes indicated here on the Olympic, within the green rectangle, are actually in the upper 1/3rd of the row of shell plating they are respective with. Continuing this line with the aftermarket kit in place creates a problem. The aftermost 5 portholes would end up being on the wrong (lower) plate (blue arrow) and too close to the upper adjacent plate seam there. You're damned if you do and damned if you don't with this. The only way to REALLY correct this , that I can see, would be to fill the entire upper row of Trumpeter's porthole locations, bow to stern, and re-drill them higher. A task I'm not willing to do. The lesser of two evils for me was to offset the line of this row of portholes so that the aftermost five are represented accurately as per the shell plates they are associated with (red arrow). A further aspect that had to be corrected, in my mind, was four portholes, (two each side), that needed to be relocated as a result of extending the upper plates by 6mm. The following is a more accurate representation, in my mind.... And finally, in all this, I had inadvertently sanded off a Trumpeter kit seam line on one side. So I purposely sanded the respective seam on the other side off and added styrene strips to rectify. Super stoked that I've completed this step with relatively satisfactory results. I'm confident it will look good once painted. Next up will be Woody's Model Works underhull plating aftermarket kit. Thanks for looking and suggestions are welcome. Cheers, Mark
  13. Sorry I haven't replied sooner. I'm supposed to get an email notification advising me of replies to this log. Not sure how I missed that. Pictures from that other site? Which pictures? The MiniBrass kit? There's a good video or two on YouTube on that one. I have an elderly aunt in Winnipeg. Hate to say it, but I might be out that way in a year or two for a funeral. She's 93. Cheers, Mark
  14. Eureka! Modeler error discovered! Or perhaps oversight is a more appropriate word. Regardless, quite embarrassing, actually. I attribute this to my lack of experience as well as just plain stupidity. Simple as that. But instead of hiding it, it should be mentioned here for a couple of reasons. 1). To help explain how my stern plating application will be immaculate henceforth (ya, we'll see about that), and 2). hopefully prevent the next person using this aftermarket kit from making the same mistake, although I can't imagine anyone else being as dumb as me in this regard. The oversight: Midwest Model Shop's stern plating kit has instructions. They are available on their website in pdf format. Part of those instructions is a layout guide. The instructions say to print that layout guide at 100%, cut out the image, and lay it out on the hull to better understand where each plate will be located. Done. This was prior to my first attempt at applying plates: As one can see, the guide does not line up with the kit seams (red arrow), and why is there a huge gap between the guide edge and the adjacent rub rail? Although not mentioned in the instructions, a further advantage to doing this is from a tip I learned from a YouTube video. Take a hobby knife and cut through the paper at each plate seam line, thus leaving score marks on the hull and thus transposing the layout guide onto the hull itself. But alas, due to the fit issue of the layout guide, I abandoned the use of that altogether and began laying the plates as described previously in this build log. So, why did I do that? Why did I not use the layout guide? This is where the dumb part comes in. After stripping all the plating of my first attempt off, I had another look at the layout guide. Here it is prior to cutting out the image: As one can see, it says "Measure after printout to confirm the page printed out at 100%". First of all, measure what? Ohhhhhhhhh!!! Measure the SCALE!! I did not clue into this my first go around. How dumb is that? On a scale (no pun intended) of 1 to 10, I'd say 10. Secondly, I had my printer set at 100%, so therefore, in my mind, how could my print job not be 100%? It appeared to me that there was something wrong with the instructions, rather than my misunderstandings. Thirdly, I'm not a techy and it hadn't occurred to me that one could print something MORE than 100%. 100% is 100%. Period. Once I realized what I'm supposed to "measure", and actually measured it (clearly in the above picture, this 100% print job falls short of 5cm on the scale), it then dawned on me that perhaps printing at 100+% is possible. Turns out it is. Who knew? Further to "I'm not a techy".....I suppose all printers are not created equal? (insert shrugs shoulders emoji here). A 100% print job on one printer might be 95% on another? More specific instructions on this would have been beneficial for an idiot like me, but I don't not want to pass blame, and I digress. So, I tried printing the page at 105% and that measured still too small by about 0.5mm. So, I tried 106%. Pretty much bang on. Maybe 0.1mm too large. Maybe. Close enough. And voila! Pics of the layout guide in place. That's better. Next step will be scoring the plate seams through the guide and onto the hull. Not mentioned in the instructions, but learned from online...these lines will not be the gospel as to where the plates lay exactly. They are just a guide. But better than guessing free hand. Regardless of all the above, I still disagree with the .010" thickness of the aftermarket kit provided styrene. I've obtained .005" and will be going with that, using the negative spaces of the kit sheet for tracing. Until next time, thanks for looking and suggestions are welcome. Cheers, Mark
  15. Stern plating update. Not going so well. I managed to address the alignment with the centerline issue, but that is about the only positive. It's moot anyway as, for a number of reasons, I've decided to strip off what I've already done and start over. The overlaps here shown in the red circles seems way too much. I'm not sure if this is modeler error or manufactured error or a combination of both. I don't see how piece #18 could have been put on any other way. I had issues with forward plates, lining up with longitudinal plate seams on the kit. This is perhaps why. I've observed a photo on Facebook of a Mini Brass application and this particular piece does not overlap as much as here. Again, not sure if it's me. The blue circles indicate gaps and protrusions I'm not happy with. This plating is .010" (.25mm) thick styrene. Again on Facebook, I read a comment from a modeler who used .005" (.13mm) styrene as they thought it is closer to scale. I'm inclined to agree with that. My next attempt will be with .005" thick styrene. This photo shows the plate seams of the aftermarket kit not lining up with the plate seams on the Trumpeter hull (red arrows). Green arrows show a huge gap between a plate edge and the rub rail. I cut another #33 plate to replace this one. More of the same. Plates just not lining up for me. Upon studying historical photos in trying to determine solutions to the above, I discovered another issue. The kit's portholes (aka sidelights) do not agree with how they actually were on this area of the ship. Granted, the photograph is of the Olympic, but this photograph is basically accepted as the best representation of what the Titanic's stern area looked like, given that they were sister ships. No photograph of the Titanic's stern exists that is better than this one. So, back to the issue....the portholes on the Olympic (and one can assume, the Titanic as well) are higher up and closer to the adjacent rub rail (blue arrows) than the Trumpeter kit portholes. I image when I get to this point again, with my 2nd attempt, I will not take the plates this far forward and just go with the Trumpeter's portholes locations. I just don't see how those can be adjusted upwards without messing with the alignment all the other portholes forward of there. Another issue.... I wasn't happy with my decision to add a 7th plate either side of the center plate of the transom area. It's just not accurate. So I removed them. That brings up the question again....why are these kit plate seams (circled in red) left exposed and what to do to rectify that? Researching this indicates to me that these six plates do not go forward enough. Using the porthole circled in green as a reference supports this. The plates in the photograph appear to end further forward than the aftermarket kit's plates. By measurement I've concluded that if these six plates were just 1mm wider, each, that would leave a more accurate representation. Therefore, I'll be cutting these plates 1mm wider for my 2nd attempt. As well, some of these plates are not high enough, it would appear (blue circle). Hopefully, I won't forget about that aspect as well, when cutting the new plates. While studying the historical photographs for solutions to the above , I discovered another apparent anomaly. The kit has three plate seams along the area indicated, whereas the photograph indicates there were five along here. I rectified this with .010' x .020" styrene strip. And here as well. Plate seams in the photograph, but not on the kit. Rectified. That's it for now. I just had an angiogram on Thursday and had two stents implanted. Can't golf for 5 more days, so I'd like to get to my hobby store tomorrow and get some .005" styrene sheet and get started with my 2nd attempt at the stern plating. I'll be using the negative spaces of the aftermarket kit sheet as a template. Thanks for looking. Cheers, Mark
  16. Progress report on the stern plating kit application.... Port side, adjacent plate #12, a portion of a molded plate seam remained exposed. I suppose I didn't quite lay each subsequent plate far enough along. So I made and applied an extra plate (#12a) to cover it. This also covered the next raised molded plate seam. The only downside is that I've created an inaccuracy. There were only three such plates forward of that hawser lead hole. Same thing, starboard side. Plate #13 (yes, I know it looks like a 12, but it is a 13...pencil lead rubbed off) did not extend far enough. It's hard to say if this is the result of my application of the previous plates sequence or some other explanation. I added an extra plate here as well (#13a). This plate would not completely cover the next raised molded plate seam, so I sanded that off (green circle). A photo in the instructions suggests that Ben did the same regarding sanding down the raised seams. Now on to the lower section. The placement of plate #14 is critical, so I decided to tape plates #14 - #18 together and do a dry fit. I also cut out plate #21, which is the plate that extends from plate #18, to ensure that plate would lay right up to the rub rail. Satisfied with my positioning, I glued these 5 plates in place. I'm using Tamiya Extra Thin cement for this. Tiny gap where plate #14 meets plate #18. I haven't decided yet if I'll fill this with putty. I suspect once painted black it will barely be noticeable. Slight alignment issue. Plate #18 is off to Port by 1mm. This should work out okay, however, as plate #21 will cover that point and I should be able to lay that plate in a manner that this misalignment will not be apparent. And just a mention of cutting the plates from the template...I have gotten better at that and find cutting the plates out from this perspective.... ....is easier than this perspective.... Until next time, thanks for looking. Cheers, Mark
  17. Hello Winnie! Happy to see another CFL fan here! Re: the FB group.... agreed, the owner definitely comes across that way, and I'm not sure why. Having communicated with him behind the scenes regarding my portholes/windows kit I found him to be actually a bit of a softy. I truly think he means well, but just has a unique way of communicating. I'm curious to know what you didn't like about the Mini Brass stern kit. Looking forward to seeing your build and thanks for looking in to my build log. Cheers, Mark
  18. Ahoy Evan! Yes, very much content with the porthole drilling and repairs complete. Regarding the stern counter plating options, if I had scratch build skills such as yourself, I likely would have gone that route as well, but alas, as essentially a beginner, I need help in some areas. Yes, I'm pleased with my decision to go with Ben's kit. A little more economically friendly than the Mini Brass kit and not as heavy as well. As well, I'm hoping my build log will help others. Just to avoid my beginner mistakes, if nothing else. Cheers, Mark
  19. After several (about seven or eight) attempts to replicate the orange peel texture, I finally have a result that I'm satisfied with. Not necessarily orange peel, but more like kiwi fruit peel. But it's generally uniform and I'll take it. The product and tools used. The first seven attempts were made using a black foam paint brush. The final two attempts were made with a white "Cosmetics Wedge". I also discovered, through trial and error, that it was beneficial to dab the foam, once wet with the product, on sheet styrene first, to get it worked into the foam, rather than a wet blob. A couple of examples of failed attempts... First pic, what a mess. Sanded all this off and tried again. This attempt wasn't as bad, but just not uniform. Orange peel on the left lapel, kiwi fruit peel on the right lapel. The trick is knowing when to stop dabbing as the product dries. Sanded all this off and tried again. The final result. Not perfection, but I'm okay with it. This closeup shows a tad inequality, but as the previous photo shows, it is not as noticeable from further back. Next step will be to learn how to airbrush and then primer all parts. Not sure when that will happen as golf season is in full swing (haha) and my Titanic project takes up most of the rest of my spare time. Thanks for looking. Cheers, Mark
  20. Stern plating has commenced. Plate #1, on the stern counter, in place. Curious to see how this plays out with the subsequent plates of this area of the stern. I'm envisioning the overlap of the subsequent plates to rise above the rub rails. Should this be the case, I suppose there are two options. Remove Plate #1 and disregard plating this area, thus going with it as molded....or....go ahead and plate it and build up the rub rails. Removal from the template is delicate. The template numbered, as per instructions. Thanks for looking. Cheers, Mark
  21. Update time, and update on the Hawser Leads. At some point I determined I got the locations of the aftermost Hawser Leads wrong, so I filled and re-drilled them a tad further forward. Upon doing research on another matter, and while looking at photographs, I had another look at these locations and concluded that I had them right the first time. Ugh. So, filled and re-drilled them again. I also decided to drill all eight of the Hawser Leads to 1.8mm. I had tried this earlier using a power drill, after having drilled them out to 1.4mm, but the bit just stuck. Drilling them out manually proved successful. 1.8mm for these leads is closer to scale. Continued with the frame kit and did a dry fit with Part Q1, which is B Deck. Upon doing so, I determined that there was a fit issue. The forward Grand Staircase of Part Q1 conflicted with not only the frame kit, but also Part W1 as well. The issue with the frame kit was not surprising, but how could Trumpeter have allowed a fit issue with Q1 and W1? Anyhoo, modify I did. Turns out I was missing a few parts in the dry fit. Oops. Honestly, I had a hard time understanding the instructions. Trumpeter has the modeler building the Superstructure primarily separate, before attaching the whole block to the hull. A few YouTube vids finally made it clear. The short of it is, I didn't have to modify Part W1, or the frame kit, for Part Q1 at all, as Parts N & P and A9 and A12 all raise Q1 higher than I had it during my first dry fit. Oh well. No harm done. As mentioned, I'm not lighting my model, so I expect the Grand Staircase interior area will not be visible much. Further, the frame kit should still function accordingly. Despite the cutouts, the horizontal frame is still solid with vertical frame. Part A9, above. Hard to make out in this pic, but the staircase is now above Part W1 and the frame kit. Port porthole fix, complete. Drilled out to 3.2mm and filled with 3.2mm styrene rod. Any cavities filled with Milliput. Sanded down and re-drilled again with 3/32" bit. I'm now happy with the results. I figure it will look better once paint is applied. As above, for the final Stbd porthole I was not happy with. Again, should look better with paint on it. More mods required for the frame kit. This time to accommodate Parts N1 & N2 and P1 & P2. This should complete modifying the aftermarket frame kit. And yet another mistake admission. I inadvertently cut a stanchion off Part N1. My excuse is that I'd cut Part N2 off it's sprue a few days before I did the same to N1. Bottom line is carelessness. Red circle shows the corresponding stanchion of N2 intact. Green circle indicates the mistake. Blue circle indicates a sprue piece I used to fix. Sprue piece filed and sanded square. New stanchion in place. I'm happy with this result. I may have to sand down the height of it a smidge as I suspect it's too tall. Time will tell. That's it for now. Applying the stern plating aftermarket kit, purchased from The Midwest Model Shop, will be next. Thanks for looking. Cheers, Mark
  22. Update time..... Part P2 "continue ridge" sanded down and complete. Corrections to Part N2. Relocate two portholes; add porthole; remove door; add window; continue ridge. Windows of the 1st Class Gangway Doors hollowed out. Two doors on each side. I purchased an aftermarket kit for the Utley sidelights from ScaleWarships. Instructions say to drill these portholes 3.0mm for the acrylic insert, but I found that to be too small. 1/8" is more like it. Here's a dry fit of said sidelight. I wasn't happy with 13 of the 2.4mm (3/32") portholes drilled so I filled them with 2.4mm styrene rod and re-drilled. I'm still not happy with this one on the port side and one on the starboard side. So, I've drilled them out at 1/8" and awaiting the arrival of some 1/8" styrene rod to fill and re-drill at 3/32". Note the damage to the rivets. I've ordered some HO scale 3D rivet decal sheets from Micro Mark that will, hopefully, address that. A tip picked up from Ben of The Midwest Model Shop. Once all the portholes were drilled out, I figured I could go ahead and work on making the frame kit I purchased fit. Not a good picture here. It's showing the third vertical modified to accommodate the porthole resin "glass" inserts. All the frames modified for the resin porthole inserts. I haven't figured out, yet, how parts N1 and 2, and P1 and 2 fit, but I expect I might have to modify the horizontals to accommodate the tabs on those parts. Wash ports. The forward Well Deck has 10 wash ports. Five each side. These come hollowed out already. The aft Well Deck has eight wash ports. Four each side. These wash ports are NOT hollowed out. I forgot to take a pic of them before adding the shutters. Wash port shutters. The wash ports had outward swinging hinged shutters. I used 0.25mm x 2.0mm styrene strip, cut to a length of 5.5mm each. Corners rounded using a sanding stick. That's it for now. Thanks for looking. Cheers, Mark
  23. Stern portholes drilled. 1.2mm. Trumpeter did not include the aft hawser leads in the mold. Port Aft hawser leads plotted and drilled here. 1.4mm. Graham's document does not have distances off any references, I assume because his resource materials did not provide any. I'm satisfied that he likely spent many hours researching it, to no avail. I wasn't about to spend many hours myself on it. I plotted my holes by simply eyeballing them based on his document and the Titanic references I have. There's a good picture of these, albeit Olympic, in "Titanic: Icon of an Age", pg 119. Looks like I messed up a bit. I plotted the forwardmost lead a little too far aft. For the starboard aft hawser leads I measured the location of the port aft leads from adjacent plate seams, in millimeters, and transposed. Trumpeter DID include the forward hawser leads in the mold. However, the port forward mold depressions were 1.4mm, while the starboard forward depressions were molded at 2.0mm. I did not discover this until after I'd already drilled the other six leads. Regardless, I drilled these leads 2.0mm. Instead of drilling the other six leads again, at 2.0mm (which would be too large), I decided to plug these with 2.0mm styrene rod and will re-drill at 1.4mm. Still a work in progress, as I need to fill the cavities with putty. Minor hiccup here. The largest bit for the Wowstick is 2.2mm. The next portholes in line to drill were the .094" holes, which require either a 2.4mm bit (which I don't have) or a 3/32" bit. The Wowstick chuck is not big enough to take a 3/32" so I used my Deko drill. Drilling these holes on the starboard side went pretty much hiccup free. However, on the port side, after only two holes drilled, the bit decided to start skating on me resulting in the next two holes to drill out of alignment. Time to stop and regroup. Green arrow shows the first two holes working out fine. Red arrows show the misaligned holes. If the styrene rod in the hawser leads above works out, I have a mind to do the same here, to correct these two holes. New plan required pilot holes for the remaining. I chose to use a pin first, eyeballing as close to center as possible to mark the spot, and then use a push pin to enlarge the mark. Then I used a 0.8mm bit in the Wowstick for the pilot hole before finishing off with the 3/32" with the Deko. Everything went well from here. So, all portholes are now drilled except for the .109" holes. I have an "Utley" portholes aftermarket kit on order from Scale Warships that require a 3.0mm hole. Upon arrival of that kit, I will then drill one 3.0mm hole and do a dry fit with an "Utley" porthole before proceeding with the rest. Another little task required was this...... There are 12 of these deck supports on the inside of the hull that require cleanup for the porthole "glass" inserts. Somewhat surprised that Trumpeter did not position all the supports so as to not conflict with any portholes, but alas, I suppose that's part of model building. Door removals. As per Graham's research as shown, and cross referencing appears to confirm, a number of doors have been incorrectly molded in and, for accuracy sake, need to be removed. Still some cavity filling required for the above. And the door removal I worked on today, on part P2, which also requires "continue ridge". For "continuing the ridge", I used 0.25 x 0.50mm styrene strip, attached with Tamiya Extra Thin cement. A work in progress. Letting it set overnight before sanding it down. And to complete this post, it is a common opinion online among other builders of this model that, for a more accurate model, both the KA as well as the Pontos detail kits are beneficial, as each have their advantages. I recently came into a modest amount of unexpected retro pay from my previous work years so I decided to splurge on the Pontos kit. Quite excited to now have this kit as well as the KA kit. And an additional bonus is that I managed to find it in my home country so, no customs duty. More to come. Thanks for looking. Suggestions are welcome. Cheers, Mark
  24. As expected, my local hobby store did not have Mr. Surfacer 500 in stock. Order placed with my go-to online supplier. It will arrive next week. In the meantime, I've masked the lapel off expecting that the procedure will not match the existing texture and will probably have to do the whole lapel. Thanks for looking. Cheers, Mark
