yvesvidal
Everything posted by yvesvidal
  1. Thanks to Firefox Caches, I was able to recover the beginning of the Build Log. Here it is for your pleasure: Folks, Here is another log of that famous little boat, made by Model Shipways at the scale of 1/32. It is a serious kit for moderate level as it is a planking on frames. The instructions are also rather fuzzy, allowing you to approach the building in your own way. The booklet going with the kit is starting to show its age and the instructions provided are in no ways comparable to modern assembly books provided by Amati or the ultimate perfection such as the instructions booklet written by Chuck Passaro. At times, this kit feels like you are actually scratch building this beautiful model. The use and selection of wood strips is sometimes rather blurry and you have to use your best judgement. Along the assembly phases, you will have to be careful about saving the wood and strips, as there is none or very little spare. The picture below was taken by a member of this forum and graciously posted for all of us to enjoy. It is a beautiful picture showing the elegant and timeless lines of that little fishing boat resting at Mystic Seaport, in Connecticut: Fortunately, the Internet abounds with information about the Emma C Berry and this forum has a couple of Logs which have helped me tremendously. I wanted to express my sincere gratitude for the wonderful Build Logs by Maurys and Anno1766 (Ovali) as well as a Russian Modeller whom I ignore the name. A lot has been said about Emma C Berry from Model Shipways, and thus I will simply present some pictures of my own model and elaborate on a few delicate steps (delicate for me, of course) of the construction. The first picture shows the kit offered by Model Shipways. This is exactly as I intend to build the model, with a view to the inside of the hull, the inside of the well and some of the deck planking removed. I got my kit from EBay at a very good price as Model Expo runs some specials occasionally. The kit cost me less than $100.00, which is a real bargain. There are also some people who are selling kits that they bought long time ago and never got to put together. It is a common practice among modellers to accumulate kits and realize a few years later than the spark to make them is gone. And so is the time and energy. The picture above from the Model Expo site, shows some of the parts in the kit. The kit provides an excellent way of building the complicated hull of Emma. We have no less than 25 frames to be glued to the keel. A stand sliding parallel to the keel allows you to position each frame perfectly. The important thing here is to position the top of each frame according to the distance measured on the plan. Also, make sure that the frames are centered. Everything else is not too difficult. I approached the gluing of each frame in the following way: Glue both sides of the frames on the plan, using CA glue. Prior to gluing, frames which need some beveling are lightly sanded but not much. It is in fact much easier to fair the hull later, when all frames have been glued and stiffened by the clamps. In addition, the fairing will be true and smoother than if you were to bevel each frame individually. You can trust me on that one: once the clamps and the deck beams have been installed, your delicate assembly of frames will not budge under the frictions of the sand paper block. With this approach, I managed to glue one frame per day, and sometimes two per day. Frames were glued to the keel using Yellow Carpenter Glue which is very hard once dried. The following picture borrowed from the Russian modeler (I did not take any picture of my build at this early stage) shows the entire set of frames installed on the keel. The view is glorious and that boat resembles the bone system of a fish. It is quite a sight. It also makes perfect sense why early ship architects would have used such approach to build boats: just observe nature and replicate it! At this stage, the structure is very, very fragile. The wood on my kit is brittle (probably old - kit was dated 2003) and you have to be careful when handling it. Fortunately, the installation of the clamps is going to change completely the stiffness of the hull. Again, on that previous picture borrowed from our talented Russian modeller, you can see the two clamps which were pre-bent, after soaking them for 10 minutes in hot water. The picture below shows the clamps installed. I glued mine with Yellow Carpenter's Glue again, for extra strength. A cloth pin was installed on each frame and left drying for an entire night (50 pins total). Thanks to the clamps, the hull is suddenly very stiff and flexible at the same time. You can twist it gently, and it snaps back in place, perfectly straight and sound. Those clamps are playing a critical role in the stiffness of the hull. At this point (and I would wait to have some deck beams installed), you could almost start fairing the hull in preparation for the planking. However, before we plank, there is all the inside and deck to be built. Since very little is known about how Emma C Berry was equipped when it was active, there is a degree of freedom which is allowed. The well is precisely described on the plan, and I decided to build mine partially open as I want to show the boat under restoration (as depicted on the cover of the kit box). Besides, that well is a unique feature on a sailboat and deserves some attention and questions from the people who will look at the model. The well is painted inside, with acrylic red approaching the anti-fouling paint used to repel clams and algae. The outside of the well is painted with Payne's Grey, also in acrylic medium: The front of the boat is simply equipped with a flooring made of small basswood strips and painted light grey with a hue of blue, of my own mixing: The rear section of the hull is equipped with two bunks as suggested by the restoration book from Mystic Seaport and the plan of the kit. Again, the same acrylic color is used. Most of the structures are made with the tiniest strips provided by Model Shipways and glued first with CA glue, and later on re-enforced with white glue for additional strength. http://imageshack.us/a/img96/6199/emma5y.jpg With a couple of deck beams glued in position, the hull is now very stiff and the fairing can be done with a block of sandpaper equipped with 100 to 180 grit. Yves
