Andrewiscookin
Everything posted by Andrewiscookin
  1. I have half a stick left! And all planked I ran around the yard with it like an airplane. Last few sticks had to be shaped to fit. I’m going to take a break then finish cutting out the cockpit and sand away. I want to cry
  2. I am so close! All it took was sitting here all day cut glue wait and repeat for a few hours. It’s getting really close on the strips and I will have to piece together the last bits to make it work. I am determined to finish the planking tonight. this was my weekend plans and so worth it to take the time to get the planking done
  3. Every weekend I look and think if I just sit for more than an hour I could just get so much done but then I look out and it’s just too nice and so I glue a stick or two and go. I like where it’s going but I should really get going so I can actually use it. Anyway more planking and hoping thinks line up this weekend boat adventure was on the schooner adventuress sailing out on the sound such a cool old boat and we had perfect wind
  4. Making a bit of progress adding sheets of balsa as a base for planking may not butt up perfectly but it will all be hidden. Carved down the walls of the hull to be flat. Up next more planking, and sanding but feels like I’m getting a lot done and closer to epoxy and paint. its boat season hear in Seattle so getting distracted on weekends but it is totally worth it.
  5. Working on the hatches today as well as making a pattern for the decking. Thinking of doing a slight change and lifting the hatch up a bit to break it up a bit much like this real version. I will skip the wind shield and think it will look better.
  6. Installing the cockpit today went pretty smooth. The seat will be removable for access to starting system held in by friction. I have any leather I want to use for the seat that I hope will work but not sure if I want to fix it to the seat or have it as a separate removable cushion. Up next work on decking one layer balsa under the planking like everywhere else even though that’s not what the plans say but I am excited to get that started. and for this weeks boat adventure we went of 4 different boats from old and slow to a newer fast passenger ferry to port orchard for a mosquito fleet festival where I saw a giant model of the Virginia v that I’ve never seen before and was very well done. Really couldn’t have been a much better day on the water without a boat of my own
  7. Roughly installed the steaming servo and need to remake the steering arm a bit longer so it can fully function. I’m thinking of making it from wood may be better than the thin sheet metal it says to make it with. What will be the best way to connect it to the prop shaft I’m thinkin a little superglue with a blob of regular glue to hold it. I am thinking that because how hard it was removing the smallest amount of resin from inside the rudder shaft tube. Feeling good about the placement of everything else and will remove and start building the cockpit this week. for our weekly boat adventure we checked out the classic workboat festival and got to see one of my favorite tugs the 130year old Arthur foss and snuck in a game of cribbage on board. We also got to see all few other beautiful boats and ones in the middle or restoration giving me deck planking ideas that I’m not sure I can pull off
  8. I will be down for the tugboat festival for sure, last year seeing the model boats and rc is what sparked this idea. It’s a short trip on Amtrak since we don’t drive maybe that’s my new end goal
  9. Lots of learning with the resin but it’s done and set it found the holes and now I get to do a bit of cleanup. Frustratingly I got some inside my rudder shaft and I cannot get it out just a small amount. I made a mess even though I tried my best with using gloves and working is small batches but I still ended up with resin on my pants my hands my arms the floor the doorknob and more lol today besides resin cleanup I’ve been working on my rudder and made it’s control arm. Mocking up electronics and making their mounts is next up after I get through and can install my rudder and actually connect and make sure everything electrical functions. yesterday took the train to Olympia for a wooden boat festival and got to be inspired to keep on building. Got to board and check out the tug Creosote that I saw last week in the parade. Also learned if you flip your boat you can just wear it like a hat because it’s Cap-sized
  10. Got a bit of filling and cleaning up the planking done and it’s looking better and better. Line of glue on the gap wipe and sand has done wonders on how it look. The bow needs some more shaping done that I am reluctant to do. Decided to test out the resin as I have never used it before and I slapped some on the dory over the paint and have started a small section on the inside of the miss adventure to see how that will go. I was using a sponge brush not sure how heavy or lite to apply. I was expecting to be totally gassed out by the epoxy but has no noticeable odor which makes me extremely happy I won’t have to work outside on in the basement. Yesterday was opening day for boating and I missed my goal of finishing this by that time but I get distracted once the weather is nice. So opening day was spent watching the Windermere cup rowing followed by a fantastic boat parade
  11. I’m excited about resin and pumps I believe I got the right stuff for the job and should have a bit of free time to hopefully get this boat finished. Picked up pumps from the boat store because i forgot them so an excuse to go on the ferry and look at more boats
  12. Finally have the bottom almost fully planked just a couple more on the rear but my sniper snapped so I stopped. The dremel made quick work of some trimming and I’ll be filling a bit and thinking of the best way to do so in between some planks that are a bit further apart than I had hoped. I was able to pick up epoxy and will be ordering their pumps for proper mixing easy from what I’ve read today I saw three whales 2 orca and I believe a small grey whale as well as a nice little red boat on my trip to breakfast
  13. Slowly going at it picked up a dremel to help and don’t know why I had not got one before. Almost done with the hull planking and will do some sanding and filling before I start with the resin. Today I’ll be by a boat shop and plan on picking up some west marine resin and hardener but not sure if I was the slow hardener or the faster
  14. Not feeling as confident as I want to be so things are going a little slower here is some weekend progress with planking that’s not as tight as I wish and the bow roughly done before sanding. For my first time doing this I give myself a b. And I give myself a d for the shipwreck in a bottle lol
  15. No my wife and I went to Poulsbo for our anniversary getaway we are in Seattle but I like going around where we can look at boats. So many models all over that small town almost every single shop had one on display
  16. More shaping and glueing planks and really liking how it’s turning out and feel like it will shape up nicely. Learning to use the bender and soaking sticks has been fairly easy and I wish I had purchased one much earlier. So happy to be back working on it
  17. Ok finally back at this as I’ve been waiting weeks as this plank bender has traveled all over the country for the last 3-4 weeks this is making planking so much easier than how I was just forcing it how I wanted (yay learning). For now I am gluing one plank at a time per side and going back and forth while soaking and shaping the planks further down the hull. The way I have been clamping the planks in place will need to change soon and I’m not quite sure how I will be doing that so I’ll get creative with rubber bands and anything that I have. So happy to be back working on it I have felt so bad just watching it sit there while occasionally catching my cat climbing on it. Also a picture of a little regatta I watched this morning from the ferry as I was waiting for the plank bender to get delivered
  18. I’ve taken a couple weekends off of building this waiting for a plank bender now. But I have spent my weekends looking at others boats in all these small shops in Paulso and then today touring the Virginia V while it is in dry dock being repaired and learned quite a bit today. Hopefully once my plank bender gets here I will get back to work daily on this project I feel bad with it just sitting there but field trips were had
  19. Was able to get the hull roughly in but It should fair well before I do the planking. Once I finally got it all in place I did a little I got a boat dance I must say. now to bust out some filler and sanding. questioning if I should varnish the sides before glueing the planks wonderful work this weekend
  20. Time for glue to dry and be back at it tomorrow love seeing it take shape and slowly figuring this out
  21. Having fun today working sides and transom. I’m adding a basswood layer to waterproof it does not say to do this and to plank right on the frame so making a panel and copying it for the opposite side nothing is glued yet and I am still shaping and fitting together. The transom I’m doing a little different and filled the spaces in the frame and a single layer of the dark wood which I will be planking over learned that I really don’t like the smell of 5 minute epoxy when I filled in gaps from the propeller shaft and rudder shaft. started layers of varnish on the inside the other night back to it I go
  22. That took way longer than it should have now to sand and do some filling in some and I think I can move on to the transom and sides You can hardly tell I messed up lol
  23. For some reason my brain could not get this figured out easily so I tried my best and it doesn’t look super great right now but I think with some filler and sanding it will be ok. Also seeing that it isn’t perfectly symmetrical but that too won’t be too far off less than a plank width. I am also thinking of making a metal cover for the bow (or make my jeweler wife do that for me) and it would cover up some imperfections. It was a very frustrating weekend and I’m tired of this particular section but I won’t be giving up just yet. Thanks for the help
  24. I slept on it and I feel dumb I was trying to force them to go straight ahead instead of bend in to the center but if I go this direction I’ll need to fill in the blank area that is created if that makes any sense. Glad I didn’t glue further than I did and if I hate the way it looks I can just paint the bottom
