Supplies of the Ship Modeler's Handbook are running out. Get your copy NOW before they are gone! Click on photo to order.
Posts posted by Adrieke
good to see you have recreated this build log too
will keep following it
hi andy
good to see your build log back up
hi John
wow Sjors
you have worked quickly to get your log back
King of the Mississippi by Adrieke - FINISHED - Artesania Latina - Scale 1:80 - with LED lighting
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by Adrieke
pictures of the assmebly and planking of the hull
at this time i had found out i didnt have enough to plank the whole hull due to the fact that the planks are only 5 mm wide and not 6 mm . the first of the errors i encountered
also the assembly of the boiler and engine room on the first deck. second error here is that the slots to fit the boiler room in the first deck or not positioned correctly. soem people made the room a bit longer i chose to just cut the front bit off and cover that hole as moaking th eroom longer meant the top wouldnt line up with the second deck
was also working on the stateroom of the second deck. i have undone all things i have done to it as i have decided to add led lights to it so i wil need to scratch build windows and doors
