Posts posted by Adrieke
all bulkheads dry fitted to mkae sure they are all where they should be. doing this i noticed that i messed up the bearding line need to redo that one
i can now rough sand the front 2 bulkheads
i noticed that the aft deck width is a lot less then the bulkheads
do i need to narrow the bulkheads or is the deck too small
haha Sjors
sorry didnt put any pics on yet
i have finished with getting the bulkheads to the proper depth
also rough sanded the top of the bulkheads as it will be very deifficult once they are glued in to use my rotary tool to sand them and will save me some time manualy sanding
will take some pictures of this later today for you Sjors
i decided not to move any bulkheads as the 1 mm difference is so small and later on when fairing al lthe bulkheads wil be unnoticable anyway
i did however took of 1 mm of the widht of one of the bulkheads . this is where the middle deck will fit in
i wil have to add about 1 mm of thickness on another one but will do that when the bulkheads are glued in
i decided to glue the 2 front bulkheads together and later on the rounded front bit.
this way i can easily use the rotary tool to do a rough fairing of the front
i drew the bearding line at the back of the false keel. its a bit wavy but it gives me an idea
i have never done this but to me it seems about right
any suggestions or comments would be appreciated
have made a bit of progress
i sanded off the 2 mm from the false keel
now makign sure all bulkheads slide in to the correct depth which means about 1.5 mm from the bottom of the false keel acording to the plan the exact thickness of the planking strips
after a few days of playing with the endeavour i finaly got round to bying some extra clamps to glue the second deck on
afterwards using a torch i checked for gaps and used some filler so that there is no leakage
you may notice the hole in the deck thats where the led lights will go for the first deck. this way no wires wil be visible through the windows on the second deck. i will also make it that i can easily take out the assembly if i ever need to replace a led.
i still need to figure how i wil hold the 3rd deck in place without glueing it on.
the last picture i tried out to see if the smoke stacks fitted
next i need to create a mold for the windows i need to scratch build
the idea is to assemble all the windows in this mold so that they will all be the same size and shape
no worries Jared
and sorry i forgot you al ready finished it just got caught up in following your nice build
yes very well done
i would also put something soft hwere the ship touches the balsa wood just to make sure
hi John
wow you make it seem so easy doing those stairs
i was struggling with it as teh steps kep showing through the gaps in the sides but with your pics as reference i ll give it a go this weekend
well done
hi sjors
its no big deal just a bit more work
and compared to the 100s of hours i l be putting into her jsut a small set back
and my wife was the one that got me off the street so its her duty to keep me off
anyway bed time for me
well that was a complete waste of time
i had cut out the keel fofrm the copies and glued it to the keel
then i noticed that instead of the paper being shorter it was longer
i checked with the plans and then i find out the copies are actualy larger then the original and totaly useless
sigh
tomorrow i ll need to remove the paper and then i ll just manualy draw the areas that need to change on
that will teach me tryiing to be lazy
alright got the copies so tonight when i am at home i can start on it
hi Sjors
oh i am definately hooked on ship building just like and Anja
this build wil be my test to see if i can put together a decent one so fixing the errors is a good start
thanks for following this build as i am grateful for any help with this
and i am following both yours and Anja's build logs
now i have to get a copy of the plan so i can glue it to the keel and start on her
i know i am probably fussing too much over it but i feel like this is my first big build and i want it to come out the best i can do
hello Pat
the difference is only 2 mm which in the real ship would be only 12cm so would probably be difficult to determine
i think i have the follow my obsession with trying to follow plans instructions to the letter. so i will reduce the false keel a bit and reposition some of the bulkheads.
while trying out the false decks i also noticed that the hole in the aft deck is about 6mm further backwards then on the drawing and the photo of the build model so i ll need to reposition that one too
that reminds me of work when at the certain time we where ordered to make temporary holes in some wooden tables to allow for cabling of computers.
would be great in the model ship buildign if we had a device to make temporary holes so we can unmake any mistakes we make
ok after another night of measuring and comparing with the plans i seem to have two options
the flase keel is 2mm longer then the full sized plans. the dimensions in the part list seems to correspond with the plans
so option 1 i make the false keel the same length as the plans which means a fair bit of sanding and maybe even repositioning some bulkheads
option 2 i leave it like it is and make sure to measure every part and not go on the dimensions in the part list. this option is ofcourse the easy way
hello Pat
wel after seeing all the issues in the other build logs i was determined to check everything very carefuly
it seems al have issues with the hawse holes as the ones on the virginia are slightly below the deck also. so i was already warned about that and will check carefuly.
the virginia was my first ship and i didnt pay too much attention to how she was planked except for makign sure there where no flat or bulky parts.
the mississippi has not really got any difficult planking so the Endeavour wil be my first attempt to make it all perfect
thanks Mark
yes i do hope we can go together soon.
hello Pat
first of all thanks for pointing out that i had the wrong scale there
for bulkhead 5 if its fitted correctly the slot didnt line up with the one for the next bulkhead. sanded it out a bit more so that the lower deck is completly horizontal. is that what you had to do too ?
wow how do you do it makign things that small ?
amazing
thank you Sjors
i havent been able to skype yet with him but talk daily to him on the phone
he is slowly recovering and in good spirits
thanks John and Sjors
still needs another coat of black .
no thank you Sjors . i dont think i could handle that much joy doing your painting as well as mine
i agree sjors it looks goot with the wire.
although i am still working mostly on the king of the mississippi i couldnt resist starting on her
from reading the plans and also reading some of the other build logs (hoping they wil be restored) there is a fair bit of mistakes that need to be corrected.
i have taken some pictures to show th errors
i am finaly getting somthing done again
first i cleaned up the small workbench i have because it was getting cluttered with all the tools an dbits of left over wood
i am painting the last parts of the paddle wheel assembly
also glued some strips of wood aginst the ceilign of the first deck. this should prevent any light escaping
i will need some more clamps before i cna glue it on properly
HMB Endeavour 1768 by Adrieke - Artesania Latina - scale 1:60 - made to look like the replica at the ANMM
Sjors
the instructions say to glue the gunwales to the outer edge of the deck and then sand them following th einclinations of the bulkheads
looking at the picture i can see that they are glued on top of the deck and not agaisnt it
but they are 5 mm wide so they would cover the smal gap and the are planked on the outside also
unless i can find something to suggest the deck is th ecorrect width i ll do it that way
thanks for you rinput Sjors and Wim
