Posts posted by Adrieke
John yes it was not too difficult fixing up the 3rd deck. i did notice that the aft 2 smaller steam stacks are slightly off compared to the plan.
soaked and fitted the first curved wall.
i also worked on preparing the other half circle room for the led :
cutting out the ceiling
make a little ledge to slide the part on
then test fitted it
the last picture shows the inner walls behind the steam stacks that will cover up the wiring inside and the ceiling bit in place
thanks for looking in Randy
hmm maybe like a small travel iron if they have that as normal irons feel too bulky for the job
its the same as the other electric plankbenders which are just soldering irons with a difernt tip
unfortunately here in oz lots of things are way more expensive then they should be
i think it could come in handy for my build (bluff bow) but i l have to think about forking out $55 for it
and you are doing a great job on your ship
progressing with the second level stateroom
the back room is ready to have the outside wall fixed again
the square part i cut out at the ceiling is for the part with the led light in.
as mentioned before the idea is that i can repair any faults in th elighting after the model is finished.
for that i wil need to make sure the parts that fit on top of the 3rd deck (see second last picture) are bended corectly so that it wil fit together without gaps and without glue
as feared after reading Johns build log on how he solved the lining up of the holes for the smoke stacks the 3rd deck doesnt line up with the 2nd deck and it wil need to be moved 3 mm to the back
almost done just the front 3 parts (they are already glued together) and the back part.
i ran out of dowel . fortunately the angel brackets where just the right lenght to fit in between th eboulkheads to keep them straight and i will put some balsa blocks in between afterwards
not sure how i am going to glue that back bit on as it has nothing to glue against at the top
shot from above shows that everything looks square
that looks liek a very handy tool.
do you steam bend the planks with it when they are on the ship ?
you are doing some excelent changes to the kit
i always love all these specialy made tools and jigs that are invented to make the model come together
yes Pat that is exactly the one. did you peek in on my workbench
yup John she certainly is a step up from the virginia
i am going to take it slow as i stil have plenty of work on the king and i want to finish her the best i can
tonight i added 3 more bulkheads .
1 more at the front and then i wil need to think on making some balsa filler blocks for the last ones
HI Ron
i truely enjoyed catching up with your build as the detailed explanation and pictures gives a good idea on how much time and work you have put into making sure everythings fits and it shows in your model which is really beautiful
not sure what is called bit its a metal rules 25 mm long with a device that you can slide and lock and meaasures 90 degrees and 45 degrees angles
i slid the ruler out to use it
also using angle brackets to keep it inline while glueing
last i use a digital calipers i measure at the false keel then lock it in
i use this to cut the dowels to the right length and then when they are dryfitted (clamped) i go round the whole outside of the bulkhead to make sure its all
the same
hi John
you make me rethink what i did to line up the stakcs which was move the holes on the 2 nd deck
maybe i better check so i can redo the changes before it gets too much work
also John make sure to draw the lines on the part that is seperated by the hole otherwise you could end up like me with the pattern not lining up at the other end
can you tell that the curved walls are also scratch made
when taking the stateroom apart to refit for lighting they broke up in several pieces.
first i was just going to join them up again but the ones for the 3rd deck stateroom are smaller and they ended up being a total mess with one bit missing somehow
i bought some 1.5mm plywood to remake them.
the holes for doors and windows are only roughly cut
since the inside of the front and back half circle staterooms wil be visible i had already decided to take out the pieces of plywood that hold the construction together
i painted the walls white and planked the floor
the 4 bits of wood strip will be used to hold the ceiling up until the other walls are bended and glued
they are also painted white so that they wil not be noticeble
it sure is Sjors
after a few weeks measuring and planning the furst bulkhead glued in feels good
i have noticed that before that those stairs can look all twisted in pictures. probably because a picture is not 3D
i finished working on the little box wiht the lighting for the first deck
it fits nicely in the deck and can be opened to pull it out
now i need to find some small connectors. to hook it up
wiht that out of the way i could now glue the stateroom onto the deck
i did not plank the outside yet as i will fill any gaps up first and then plank over it
i wil now also be able to fit the piece of breadboard with the resistors in teh compartment at the front between the 2 smokestacks (will put 2 walls in painted black so it wil be invisible from the outside
wow Doris you are a sculptur, painter and modelbuilder all in one. what you create is amazing
and you work so quickly . in the time i can only do a bit of sanding you created Pegasus.
that looks really really good
it makes it look so much better when all these small things come togeterh
i still have a long way to go before i am up to that
HMB Endeavour by RGL -FINISHED - Artesania Latina
nice progress Greg
i am hoping to visit the replica and take some pictures of my own
