Phoenix_63
Everything posted by Phoenix_63
  1. Cheers Antony, I thought about replacing the bearings with taper jobs, but I think I'll wait until the existing ones fail (if ever, this will only get light use). Likewise the gears. Metal sets are available but I'll see how it runs 'as is'. I will probably get some decent tools next month, I have used lathes before and have a good friend with an extensive workshop to help me get started. It is my intention after New Year to polish the gibs and reduce the backlash on all screws as well as centring the tailstock. I may do a post on this process but I get the feeling it's been done to death!
  2. Collected this morning! They were in the process of replacing the splash back (well, that's what I call it) but hadn't finished; they explained this was being done when I purchased the machine as it was bent in transit but hadn't finished it and as I will be stripping it down to clean it & 'fettle' it I took it as is, they gave me the new one to put on. They also did me a deal on a 4-jaw chuck, live centre, QC tool post and tail stock chuck. They have a lot of accessories available such as metal gears and cutting tool sets and a whole range of other tools from various manufacturers but SWMBO would lynch me if I bought more at this stage! I will certainly use this company again, excellent service & advice. You could buy the same lathe for more money with a different badge on it, but why? I will certainly continue to use Amadeal in the future.
  3. WWW.AMADEAL.CO.UK Very helpful over the 'phone, open for long hours. Based in Leytonstone so not far! (I'm in Gravesend). I pick mine up on Saturday!
  4. Well, following tkay11's advice I followed a few web links and I have bought a CJ18 Mini Lathe from Amadeal. It has the leadscrew and by the time you factor in things such as compound slides etc the price difference wasn't that great; I guess these all come from the same factory at the same price in the far east but Amadeal aren't that far from me and were very helpful over the 'phone so they got my business. Pick it up on Saturday but waiting until my new shed is finished early in the new year before I use it in earnest. that should give me a few weeks 'fiddling time' to sort it out! Scott
  5. Hi, for a while now I have been considering a small lathe. I was tempted by the Unimat SL but they seem to be going for monstrous money on eBay! I have found a Draper 22816 which seems to be similar; It is a 'micro' lathe which can also be used as a mill and a drill press. The biggest drawback I can see is the lack of a leadscrew, so for parallel turning one would need to be very accurate in setting up the cross-slide. The biggest advantage is the price, I can get one for a little over £320 which seems quite good. I also looked at the unimat 6 in 1 but that doesn't inspire me with confidence for metalwork, being plastic and 12v. I will only be doing small modelling projects, perhaps a small sterling engine. Would the Draper be ok do you think? Confused of kent...
  6. Hi, I've just joined this forum and for Chrimbo I am looking at the better half buying me the Victory Cross section or Bow Cross section or Panart 'between the decks'. Having looked at various logs on here I think it will be the Panart or this model, but I don't know if I can replicate such impressive work; especially the planking! Absolutely stunning, can't wait to see the finished model. I can see the benefit of some low power LED lighting, will have to look at local stores for possible products. I am tempted to start with the Panart kit then progress to this beastie! Loving it...
