AON
Everything posted by AON
  1. Thank you Allen That will certainly challenge things for me! The green line is the aft or stern body plan. It is green only because I "picked it" to highlight it in the view, otherwise it would have been grey/black as in the two views immediately above it. Alan
  2. Sorry! A picture is worth a thousand words.... this should be better than my trying to explain it in just words. I think they must have made them with an angled face but I do not know for certain. Alan
  3. Thank you Joe. It just doesn't seem as exciting to look at as the physical build. My frame -0- model is about 50% done. Had some issues with the "joinery" between futtocks... but I'll explain that later. (A question for all the experienced modellers out there...) I have often claimed 'there is no such thing as a dumb question' but I am beginning to doubt that at this moment. I am wondering, do the actual inner/outer frame surfaces angle to mimic the inner/outer profile of the hull? One "square" frame up against another "square" frame set in or out a bit to follow the half breadth doesn't seem right. Looking at the plan I believe the framing is full/solid, one nested against the other. Alan
  4. I completed the finicky tweaking of all points on all section lines. Had to make compromises, blending well and looking aesthetically pleasing won out over clashing dimensions. This is the last batch of section line development sketches. I am going to model section -0- frame because I need to do something different before I go back to more sketches... I am certain many following may be getting as bored as I am at the moment (plus my head hurts!). I think the momentary change will recharge my batteries! Alan
  5. DOH! Sorry, my head is into the other problem! It's the lubrication of course! Not too much though or it quickly becomes the worst tool on the desk. I also found I have to look straight into the magnifying glass to get a good measurement reading, looking at a slight angle throws the cross sight hairlines off. Wish I had a 60 inch monitor so I didn't need the magnifying glass.... now that would be one beauty of a tool on the desk. I tried doing a split screen (like in 2D AutoCAD) but couldn't figure out how... possibly it doesn't have this feature. It definitely is not mentioned in my reference book. Alan
  6. Try this site to calculate three points segments on a arc of a given radius. http://www.mathopenref.com/arcradius.html Then if you like draw a scaled down version and scale it up and see if it matches. I would hope they do. I am using SW2007 and do not yet know if I will have the same problem some time in the near (I hope) future. Alan
  7. Sorry, I don't understand. "Which one" what? I am going to assume what the question means and so that answer is: The actual original plan views do not match each other. The Breadth plan as I plotted it has one point seemingly out of place a wee bit ... likely me. The original body half plans at -0- station are not identical. I've measured them a quite a few times to make sure it wasn't me... hence everything before or after them is out somewhat similarly. I can accept this is normal for a pencil drawing. You can only be as accurate as the point on the pencil and the sharpness of your eye. Today with 5 decimal place dimensions on CAD drawings it would not be tolerated. Them were the good old days. Alan
  8. It finally got stronger than me. That little feeling that something just wasn't right The dimensions from the half breadth do not agree with body plan The -0- station body plan versus the stern and bow plan outer most waterline and top most end points should match but don't The body plan aft points are inboard and the forward points are outboard ... and not at equal distances I tried to keep my measurements as accurate as I could so I attribute it to a combination of original paper/pencil draughting error, original paper distortion over the centuries and of course ... me. Although I only have four stations to go I have to stop and make the corrections choosing the half breadth as the plan to follow as closely as possible. My only consolation is that at the scale my build will be no one will notice so long as the points are near and blend seamlessly. Alan
  9. Progress to date Stations 2 to 16 yet to complete Once this stage is done I intend to review them all together and assure their shape is consistent with the original plan (nothing looks out of place or odd). When I am happy with this I will add an internal detail sketch (deck levels) One step at a time ... long way to go before creating 3D part models (templates) Alan
  10. Made further progress, plotted all intersecting points for stations (2) to 30 waterlines. Completed upper outlines at the Aft or Stern Perpendicular and sections 29 and 30. Need to complete (2) to 28! I will post some images when done this stage. Meanwhile here is a picture of my CAD workstation. Can you spot the most important tool on the desk? If you picked the magnifying glass your wrong (it would be number 2) Alan
  11. Today's progress.... Managed to get from -O- to Y Foward Section Lines done. I measured these off the Body Plan and compared to the Half Breadth Plan. They are not too far off and blend nicely .. but it took some manipulation of a few sections to look right. So far I am happy with the out come . Next are the Aft Section Lines. But not tonight Alan
  12. Had a request for help interpreting a perceived problem... if you had read it I just deleted it as I figured it out. It was a 3D illusion. Alan
  13. Thank you Anthony Like yourself I am by no means an "expert" with Solidworks. Having been laid off work for a 1-1/2 years during the economic slump a short while ago I purchased a "how to" book on Solidworks by Sham Tickoo (it stays on my desk for reference) so I could get back into the game as everyone wants 3D models now. When I finally beat out the 1000 other applicants and landed a job I needed to know how to use Inventor! Went back to the proverbial drawing board and started all over again. Thank goodness they are somewhat similar. At present I only use them on side jobs because my new (back to an old) job has other people drawing. My secret is I try to keep it simple.... though I still need a "do over" occasionally. Alan
  14. Making some progress. BODY PLAN LAYOUTS I needed to delete the reference points in all underlying planes (Station or Buttock Lines) because they showed through to the plane (station) I was working on and it was confusing. I had to go back and clear up “dangling” errors as I had located my water lines to them. Vertical and horizontal dimensions added to the water lines fixed this. Alan
  15. i just type in the box (like here) then pick "More Reply Options" below on the right this opens buttons to add pics (attach files) Alan
  16. Regarding the book I received from Inter-library loan. It came from the Coast Guard Library according to the stamp and originally cost 30 lbs sterling (about $60 Cdn back then) “The Masting and Rigging of English Ships of War 1625-1860" by James Lee. Repeats some of the info I have in the new library I just acquired from a member but lots of photos and diagrams. Might be worth the purchase. Alan
  17. GOOD CATCH! Shear vs Sheer ... it was a a typo ... honestly! I drew the water lines on the sheer (!) plan. As they are sloping straight lines I needed only the measurement at the stern and bow perpendiculars. I then open station (or buttock?) line Y (just in from the bow perpendicular), projected the water line locations for "Y" from the sheer plan and inserted and located my points based on the water line height and measurements I had taken off the real plan PDF image. Then I drew in the shape following the points and then finally mirrored it. The results are below. I now only have 30 more to go! You are right though regarding "proving", and I still have quite a bit to fill in on the sheer plan. Alan
  18. BREADTH PLAN LAYOUT STEPS 1. Draw each station line · As there are quite a few at the same distance apart (5.3 ft) this can be done quickly with the array command · The first line must be anchored and fully defined to make the others fully defined. If it is not anchored/fully defined the line might accidentally wander later on and cause endless grief When the line or point are fully defined they change colour from “BLUE” (free to float around) to “BLACK” (locked in place). 2. Anchor one end (coincident mate) of the station line to the shear line (centre line) 3. Lock the station line in the vertical position (vertical mate) 4. Locate its spacing with a dimension to anchor the spacing 5. Insert "points" onto the station line (these look like * an asterisk) 6. Anchor each point (coincident mate) to the station line · If you pick all points in one row and mate them as vertical and then pick one and mate it as coincident to the line they will all lock into place quickly 7. Anchor the distance with a dimension as recorded off the actual plan from the shear line to the point. If the point does not change from blue to black it needs to be anchored as I missed it. 8. I “exit sketch”, “rebuild” and “save” after every set of station points has been completed. 9. When two points lay directly over each other I add the unused point outside the plan but do not dimension it. If for some reason I might need to tweak point locations to smooth out lines I might need that extra point (I could just add it later but as I am doing them now…. Why not?) 10. Once all points are plotted and double checked I drew spline lines joining the dots (or asterisk type "points"). · NOTE TO SELF: next time do one set of points for one line at a time and draw the spline before going to the next set of points. Trying to figure out which points went with which line was a bit of a head scratch in some tight areas. Of course this means more work anchoring each individual "point" · A couple of the lines seem to be off as compared to the original plan. Likely the reference point locations need tweaking. I will wait to get the body plan done before I do any adjustments. 11. Once all lines are in I mirrored them just for show. Now on to the Shear Plan. This should be quicker as I'll just show the lines for now and get the internal details later. Alan
  19. Gil, You are absolutely correct. We are our worst critics. You have no choice but to make it right for yourself because of all people you know it is there! I for one greatly appreciate your expertise and attention to details. Me bored? Not one iota! Thank you Alan
  20. I figured out my rookie error last night and managed to get all my reference planes representing the shear, breadth, station body plans in place and labeled. Had to abbreviate the labels as I could not read them. I also changed the dimensional units to feet so it relates directly to my spreadsheet measurements. Below is the extremely minor progress I made .... my day job seems to take the wind out of my sails at night and early morning didn't seem to be much better for me... might have to give up the day job so I can get this done On a good note I received notice yesterday that my inter-library loan book came in: “The Masting and Rigging of English Ships of War 1625-1860" by James Lee. Will be picking this up today. We have a stat holiday Monday (Family Day in Ontario) so over the three day weekend I hope to do better in the transferring of points and lines to the planes / plans.
  21. Decided to draw what I can on the breadth and shear planes / plans so I can use these as reference when doing the individual body plans at each station. Started by drawing in the station locations and the dimensions didn't work out as compared to the spreadsheet. Each end is out of wack (too short or too long). This defies logic. Thought I might have got it reversed and ... nope. I must have made an error somewhere but it is early in the morning and time to get ready for the real work day. Have to revisit this in the evening and hope the error leaps off the screen when I am wide awake
  22. Thank you Alex. I had slept on it and could not imagine any advantage to building with the keel sloped other than to mark the W.L. horizontal. I can easily make a jig to accomplish that ... but I wasn't certain if I might be missing something by not thinking outside of the box. I had decided on the Elephant as my primary source as it had the deck plans available. The Goliath will be my backup for any details that might be fuzzy. Your view on order of staging the drawing is not what I had intended... Now I'll have to rethink that. To me all the internal details seemed secondary (filler if you will) to the outside shell. I can see the advantage to getting the W.L. marked on the sheer plane (to assure they are properly located in the body planes) but admit I need to go back to those wonderful books I just acquired to make sure I understand and fully appreciate what you are telling me as many of the terms are not recognized by me as yet. This will change! This will be a delay in my progress a wee bit but might very well save me tons of aggravation down the road! If there any any other recommendations by you or others they are most welcome!! Alan
  23. Thanks again! Would you think it would be smart to set up the model build at an angle so the waterlines were horizontal for the build? I got a wee bit of a second wind after supper and got a small start on the CAD side. I should mention I am doing all at this time in construction lines not object lines. I intend to copy the file as individual station numbers and then change the sketched lines to objects and build the 3D parts Then I will create an Assembly file and put them together. I may change this thinking as I progress ... have to see if it still makes sense.
  24. What a learning experience this has been! Found the "stretch" in the drawing while measuring and had to go back and double check everything I did in the Shear Plan. I attribute it to the accuracy of a pencil plus the 250 years of storage. Had to compromise on a ratio and accept the fact that it will not be exact. Consoled myself with the fact the actual build likely was not exact either. Reworked my spreadsheet (see partial image below). I did some comparison to the Goliath plans and they seem very much the same although drawn by two very different draughtsmen. There are differences to be seen between the plans with regards to the railing over gun ports and railing height at these gun positions. Elephant rails rise over the two gun ports on each side and Goliath flows level over one and is cut away at the other. Possibly more to be found yet as I spend more time with them. One other thing that played with my mind was that the waterlines in the shear and body plans are sloped. I thought they'd be horizontal. Going to start my CAD drawing next but not today... my head hurts.
  25. Completed collecting data from HMS Elephant shear and half breadth plans. Need the waterline heights yet. Will do same for HMS Goliath (tomorrow?) and compare just for the heck of it to see if there is much difference. I should be able to start transferring the data to CAD soon. I should also mention that in the PDF program settings I was able to lock the dimension tool to read perfectly horizontal or vertical so no math needed to be done!
