I am planning to do a scratch build of the Rattlesnake using Harold Hahn's plans. My question is: can I use a 3/32" sheet plus a 1/8" sheet to make up the 7/32" thick frames?
Thanks, Wally
Do you plan to fully plank both sides of the hull?
Yes. - Then it should do.
In making the sandwich, with PVC glue - within reason - higher clamping pressure = stronger bond. Uniform pressure for all sandwiches will yield reproducible results.
No -  Will it bother you that each displayed frame will have an offset seam near the center with a different grain pattern on each side?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
