Hi all, has anyone used the dremel ms20 moto-saw. As I have limited space in my dockyard I thought this could be the ideal scroll/ fret saw.
Brian
Brian , I bought one a while back and used it a fair bit . It is handy for small cuts but don,t expect to cut anything to big , I bought finner blades for cutting sharper corners and they worked well but you need the bigger blade supplied to cut straight  . The blades are cheap and easily replaced . The hole around the blade is to big and small pieces will fall through and if you have the vac connected they will dissappear but this can be easily solved . It has a variable speed which is usefull and although noisey i think i could call it value fo money .
Boyd .
