  • 6 months later...
Hello 1213brett, did you ever get an answer to this? The reason I am asking is that I have just posted the same question over at the ShipsOfScale forums. So far there have been a couple of responses but I am not convinced either way and I came across your post and want to see if someone helped you or if you figured it out since you posted this.
Thanks,
Dan
maybe this helps,
If you search for "Mayflower"
Then you will find interesting building logs of the mayflower. Not from the same manufacturer but they can perhaps give the solution to your question (see example)
1 hour ago, dstrosch said:
Thank you very much Patrick. I thought I searched the NRG forum but I don't recall seeing this. Even though it doesn't look it is from the same manufacturer this helps a lot.
Dan
you're welcome :)
Go on the Model Shipways site and find the SYREN. Open it up and the open instructions, Chapter 1. This shows the absolute easiest way to make a rabbet.  Simply put, sand a little bevel and then glue on a wood strip. Eliminates much of the knife work.
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
