Good afternoon misters
решыл to show you extreme the self-made machine tool I will begin with manufacturing process
Did two months of a photo process it should be clear
If there will be questions with pleasure will answer
I am sorry for my English I write through the translator
Anatol
7b8800178abd.jpg8eac5a1aaf78.jpg108385712345.jpg188b1d8955e4.jpge56e0da9b124.jpg8533e4ccbd6d.jpgdbed3cde680e.jpgcdac319e9071.jpg3cf4b3b9625a.jpg835ba187da87.jpg
4db66ecc4255.jpge3876c95feb5.jpg97cc704a8299.jpgef448a5a547c.jpgb2fbbad0f1f9.jpg6d3cfc22abed.jpg62c820e24b2f.jpg90aa1284ae17.jpg7c921af077f6.jpg141fdaeafbaa.jpge5574310eb19.jpgSmall deviation from a theme
I was registered at your forum to watch construction
Bonhomme Richard 1779 CUZ itself I try to do такойже
Simply be the spectator I can it is not necessary to accept participations in forum WRK
Therefore I share that I have that can to whom it is useful
The lyrics came to an end
Continuation
The termination
Short characteristics a drum 80х82мм a horizontal table 300х115мм its inclination from 0 degrees to 50градусов
Working zone under a drum 28мм, speed from 0 to 2500 turns in minute, weight 25кг
And for the sake of a trick it is twisted screws, bolts, nuts 131штука, 60 details of +14 bearings + a belt + the motor are soldered, braided together
I am happy
For polishing of small details
The size 255х84х18 in a cathedral kind, length a mobile sponge 60мм, a screw course 30мм, apertures 4мм under development
 For polishing the detail fastens between wooden hairpins, hairpins will be shortened (a thick part) in a thickness of a ground detail
All
631117ec2a6f.jpga665ffd4dda0.jpg59fba9fe39b1.jpg703513c933ab.jpg0b17a751ac5e.jpg41461dc3ffd2.jpga3f0e7cc96a2.jpgfc84ebc4ccb1.jpgd02f734fa8e3.jpg
I am speechless with the construction and the wonderful result.
Congratulations Anatol.
Gregory
Gregory Kamtsikoudis
Hello, Anatoly!
  :722972270:
The interesting machine, but quite metal-consuming and difficult in production - is a lot of details without which it is possible to do, using the direct drive, instead of a belt drive with all its shortcomings.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
The fundamental set of  tools - . And instrument interested me ostatni already particularly. can you  publish or send jakić drawing with dimensions?
I greet
Kacper
Toly,
I too am lost for words - Wow says it all.
I am most impressed with your postings. I have added you to my list of names that I look out for amongst new posts.
Ian M.
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
