Mondfeld in "Historic Ship Models" (p. 144) indicates that an opening in a ships deck to allow access below is either a "companionway" (merchant ships) or "ladderway" (warships).  He then describes a "companion" as an opening in the deck of a warship that provides light and ventilation and is normally covered by a removable "skylight" but that is not a ladderway.
I ask because the plans for SYREN provided in Chapelle's "History of the American Sailing Navy" (p. 185) indicate both a "companion" and a "skylight" aft of the capstan, but no ladderway.  Trying to reconcile with Chuck's plans (ie. did Syren have a skylight too?).
Any insight appreciated.
Keith
In my experience a companionway and a ladderway are synonymous. A companionway will always have a ladder.  The skylight is a separate thing entirely; it only provides light to the lower deck.  There is no place for your `companions` to make their `way`below deck.  Zu Mondfeld is wrong.
Regards,
Henry
Laissez le bon temps rouler !
A companionway/ladderway always needs a bigger opening with larger distance in between the deck beams to pass ladders, sailors or even goods. A skylight can be only a part of the deck not being planked and showing the deckbeams underneath running through the opening. See for example HMS Victory for that detail.
http://www.mediaharmonists.de/bilder/Sammler29/Victory-161113_2569.jpgVictory-161113_2569.jpg
XXXDAn
Edited by dafi
Thanks for the replies.  To help illustrate my confusion, below is the relevant section of the drawing from Chapelle, an unknown model of Syren from the web, the USNA museum Syren (Lightly model), and the MS Syren configuration (Chuck's interpretation).  I'm still conflicted on exactly which deck opening(s) would most likely be used for access below (i.e. the ladderway/companionway) and which (if any) would be a skylight for below deck lighting/ventilation.
Any thoughts welcome.
Cheers,
Keith
And do not forget, ships went through a lot of changes throughout their career :-)
So sometimes there is more than one possibility. But the original draughts are always a good "inspiration".
XXXDAn
