I rigged as much of the lower foremast off the model as I could. Now when I installed the mast I needed something to keep the pre rigged lines off the model and not get snagged on anything. I picked up a couple of those plexiglass picture frames that you slide the pictures in between the plexiglass. I placed one on each side of the model to hold the lines off. Then I could work on the lines without snagging or getting caught on anything. It worked great as I was installing the swifter.
Geoff
NRG member #2666
Current build : USS Constitution
Finished builds: Armed Virginia Sloop (in gallery)
