Hello Ferit, I asked this question last year. The general consensus of opinion was that the flag halliard sheave or sheaves usually run fore and aft either side of the mast.
Dave :dancetl6:
Edited by davyboy
16 hours ago, Ferit KUTLU said:
Then I have to make miniscule hanging blocks...
Ferit,
Why would you make hanging blocks for this ? The flag halliard sheave is fitted into the Mast Cap. Just drill two holes close together in the mast cap running fore and aft to simulate a sheave.
Dave :dancetl6:
Hi Dave,
If I understand correctly:
The mechanism on the drawing is correct but the location of the sheave is not. The halliard comes from aft to fore... (the sheave is just on the center of the mast cap, the halliard jumps from aft to fore over the cap.)
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Hi Ferit, go back to page 3 on this the masting,rigging and sails section. The third thread down is the question I asked last October. 4 replies,1 diagram from Levers' book,a photo of an actual mast cap/truck and a photo  of one of Doris's Ship model caps. Your two pics show the flag halliard going through a hole over the top of the mast cap then down through another hole. There should be a sheave fitted there,otherwise the flag halliard would be quickly worn out.
Hopefully that will answer your question.
Regards,
Dave  :dancetl6:
Edited by davyboy
Hi Dave,
First of all, I'm sorry to ask again a question that has already been asked and solved... I have missed it...
Being so far from terminology I don't understand many things without illustrated narrative even if I translate the typed text.
Now, it is clear after the pictures in your topic.
Thank you for your interest and help...
Best Regards…
Ferit KUTLU
