Does anyone know if Corel provided more up to date instructions for this build? My booklet seems dated with a paucity of information presumably because it's aimed at the more experienced than myself!
The Victory is for the experienced builder indeed.
Having built a Corel model before, I don't think the written instructions are much of help, neither I believe there is an update, as these are pretty old kits. Corel kits are share the same design principles though, and you can find several examples on this site. I recommend going through the great Belllona log, which shows quality work and very detailed:
The Corel Victory is a popular subject, and I saw great models built from it. Start a build log here, and ask, if you have questions. Support of fellow builders will be much more help than any instruction book you find.
Good luck for your build.
Past builds: Prins Willem,  Amati Coca
Current Build: Occre Diana
Thank you, I will have a good look around the site. It's great to see so much information from experienced modellers and novices alike.
I started a build log ages ago now and must revisit it when I've got a few more planks on!
