Hi guys, I've just downloaded all the drawings for Triton as I intend to eventually do all three builds, I thought I would start with the POB as I have done POB kits in the past. So my question is what scale is the centreboard drawing as I need to resize it to 1/48 scale.
Many thanks.
Brian
Welcom to the Triton shipyards, Brian.
As far as I remember have all drawings the same scale: 1/48. So you have only to check, that you print every frame with 100%. For safety you can check the length of the ruler: 240'' = 127mm in 1/48.
Regards Christian
Hi AnobiumPunctatum, thanks for the reply, the reason I asked is because the bulkheads are at 1/48 but the centreboard is a lot smaller, I think it's about 1/96.
Brian
