I see on a few build logs where some people pre-taper the hull formers by laying the smaller ones on the larger ones and drawing a line and sanding the taper.
This looks like a good idea to me but is there anything I should be wary of or do you not thing it is a good way to do things?
Paul
Current Build: HMS Winchelsea 1764 1:48
Completed Build: HM Cutter Cheerful-Syren Ship Models 1/48
Completed Build:  Artesania Latina Bluenose II
Completed Build Lady Nelson
If you mean fairing (shaping) the edges , this will only work if the layers or frames are almost in contact with each other. In the case of a model with bulkheads, where they are spaced far apart, you can only fair them after the framework is assembled.
