Duco Cement is fairly fast drying - hold pieces together for 20-30 seconds. It is a nitrocellulose solution in acetone, and the acetone evaporates quickly. It also has a strong smell and is flammable.
I use Sig Bond aliphatic resin for most work and clamp the pieces together. It is slow hardening - 40 minutes to hold and over night for full cure.
If you need to bond to metal or glass use epoxy!
Phil
Current build: USS Cape MSI-2
I seem to mostly use Gorilla products.   Gorilla PVA Wood Glue for the majority of the build and then I have Gorilla CA glue which I use on the ends of ropes or adding that 1 piece that needs to bond quickly.   If I have plastic pieces, either the CA or Tamiya Extra Thin.   I have been using Gorilla CA for years now and have never had a bottle dry up and my current bottle of PVA is well over a year old and no sign of it drying up or getting old.
Current Builds
Billings Boats Norden 603
Trumpeter R/N Fiume
Upcoming Builds                                                   Completed Builds
Billings Boats RCMP St Roch                            Model Shipways Norwegian Pram
        Midwest Models Lobster Smack
        Model Shipways Dory
I stream my builds live, join me at  https://www.twitch.tv/bartbandy
