Yet another Pram build :)     My adventure into wood ship building continues.
After completing the Dory (sorry I did not find you all in time to make a build log);
PXL_20240528_211946249_MP.thumb.jpg.86c85e6088ffa52b62d606685a910cd9.jpgPXL_20240528_211858740.thumb.jpg.f8773cf01ea740b8c17c796409e4bdad.jpg
It was time to start the Pram (this time I will do a log haha.    Early stages and just getting started.    I do stream on twitch when I build so if anyone cares to check it out, you can find me over at BartBandy - Twitch
PXL_20241006_153117931.thumb.jpg.0320374a6ad3b8cfd8ea13444abfd466.jpgPXL_20241005_151840669.thumb.jpg.888e4d896e2600f17af0517aadec8b51.jpg
Current Builds
Billings Boats Norden 603
Trumpeter R/N Fiume
Upcoming Builds                                                   Completed Builds
Billings Boats RCMP St Roch                            Model Shipways Norwegian Pram
        Midwest Models Lobster Smack
        Model Shipways Dory
I stream my builds live, join me at  https://www.twitch.tv/bartbandy
A bit of work this morning.   Have the garboards soaked and fitted, letting dry and will glue down later today.
ship2.thumb.jpg.3944d58d3d2c9bf4553e3d4bc0cd7480.jpgship1.thumb.jpg.8db9218670d8239fbf24a319df96efe2.jpg
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
A few minutes in between all the sunshine to get some work done on the Pram.   Discovering I need to be a bit less religious about reading and following the instructions and instead use my own eyeballs to see where things are fitting and where they are not.   As you can see on the ends where the overlaying of the planks was not the greatest.  Lesson learned.   But having an excellent time and those who watch on stream, all plastic builders, are enjoying seeing work done with wood.
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
Some more work this morning.   We are going to need more clamps!   :)    My dagger board thingy was too small for the hole as well as others have been experiencing so had to fill it in a bit.
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
I big thank you to those who have build logs for the Pram, the instructions have definitely had me scratching my head a few times and several of the steps have no photos or any real explanation.   Probably not an issue for most people but for this noob, it has me scratching my head - lol.
Looking a bit rough but cleanup to come after the glue is all set.
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
Small update from yesterday,  trimmed the bow and stern, got the rowing thingies in place and the rub rail.   Seems I don't own a 3/8" file for the transom so will have to make a trip to the hardware store (twist my rubber arm).    I do stream while I am building and can be found over here as BartBandy
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
1 minute ago, Dan Poirier said:
Double-check the 3/8" size, it seemed awfully big to me. I thought it might be a typo for 3/16".  (Ultimately, I just free-handed with a smaller file rather than buy a new one just for this.)
good point, will check that.   Thank you!
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
Actually, one has better control using a larger tool. You will file across the transom rather than along it. (For model work I usually use a ½" bevel edge chisel  - or larger - a lot of the time. One can judge angles more easily than with a narrow tool.)
A productive weekend, got the rub rails cleaned up, the rudder ready and shaped, dagger board built and hopefully thin enough that when the paint goes on it still fits :) and the rear transom carved out.   Time to get to the store for some paint, getting close.
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
I think he's referring to the notch for the tiller. I found 3/8" to be massive also and thought they meant 3/16". The etch mark is closer to that size. I skipped that part until I assemble the tiller then I'll fit it and decide which way to proceed.
Looks like Scott used 3/8" above which doesn't look bad at all.
On the slip:
On the drafting table: OcCre Polaris, Muscongus Bay lobster smack
Completed: Lowell Grand Banks DoryNorwegian sailing pram
On 10/29/2024 at 2:42 PM, EspenT said:
A ship modeller on Twitch! Nice. I will try to catch you next time you go live.
I am ordering the 3 starter kits from Model Expo.
You are always welcome, just started streaming again after a bit of a break through the holidays.   On there as BartBandy, should be easy to find :)
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
It has been awhile since I updated or did much building.   My fall hiatus :)
Got all the parts painted up - not a fan of brush painting or the Model Expo paints, will be going back to using my airbrush and Tamiya paints and Vallejo when I need to hand brush.   Just find these paints so thick.
and it was at this moment when I realized I had f@#$'d up.   I thought it was just a line that paint would go over, nope, time to sand it down again.
That's better, although I am not a fan of how this paint goes down.  But to be fair, a real boat would have tons of thick paint.
hmmm, might dull this white down a bit.   Hind sight being 20/20, I would lighten the red and blue up but will see how it looks in the end.
Have decided to try the square version of the mast first - if I don't succeed I will use the dowl.   It seems the kit is short one of the V's for the jig... shrug.
Ok, I know others have pointed this out, but what is up with the provided nails that are too damn big for anything?  I can order up smaller ones from 3rd party sites, but the shipping costs more than the nails.   Gonna try and cut the tops off and see how it looks, but if crappy, will have to wait for my next run to the hobby store.
Got the rudder put together but I did not bend PE around the tube.  I put the tube on the outside.  I am still pretty limited in my tools for this kind of work so had to cut with the Dremel so the edges are rough.  I put the tubes on the outside (have seen it done both ways and I kinda like this way).    Still some cleanup to do on the brass pieces and figure out the bolt heads
Overall learning lots from this kit, mistakes are there but having fun and can see my skills improving.  What a difference from plastic boat building.   My biggest complaint at this point is the instructions with this kit.   I never thought I would say that something is to verbose but damn... these things are wordy and assume you know every term for every part on a ship.   Finding I am having to break down each sentence one by one.   Or just flat out ignore it and follow videos on youtube.
Hope everyone had a great New Year and have wonderful builds in 2025!
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
Very nice job so far.  I think the paint job looks pretty good.  The white is a bit white, but it is a new boat!  I think the simplest solution for the nails is to get some brass sewing pins.  You can get more than you may ever use for a couple of bucks.
  - Eric
Three hours of sanding and got the mast, boom and 2 oars done.   Broke the gaff (should have heeded the warning of others....) but have it repaired.   2 more oars to go.  Did sandpaper companies invent this hobby to keep themselves in business?   Curious minds want to know 🤣
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
and a coat of varnish for everyone!
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
I had the same confusion over the round file. I bought a 3/8" one on Amazon and after starting filing realized it was way too big. It was probably supposed to be 3/16".
I don't know why Model Shipways doesn't issue a ver 2.0 of their Shipwright Series. I wonder how many builders don't find a web site like this for answers, get hopelessly confused over the instructions, incomplete parts, and the wrong parts, and just give up. You'd think they'd see the benefit of doing a review and update of their entry-level kits and make sure the instructions are clear (and correct) and the parts are the right ones. Model ships are already challenging. They shouldn't make it avoidably harder, especially for their kits that are supposed to be a beginner series. I can't imagine having been able to complete these without reviewing other build logs.
I ended up using some thinned wood filler on the transom to fill in those lines (which I also didn't sand/file down to), sanding them down, and painted.
Edited by palmerit
I completely agree palmerit.   I am surprised that they have not made the little tweaks to get this back into the beginner category, unless they like the confusion cause part of learning is how to figure it out on your own?  haha.    I have new nails coming - I had to order something from somewhere else who had the right size so spent a few bucks instead of going through the complaint process, I missed that the mast diagrams where out by about 3% so I ended up removing about a quarter of an inch from the mast when I shouldn't have, so I hope that does not bite me in the backside.   Now I am trying to decypher the instructions on how the hardware goes on the mast, that will be todays challenged  adventure. :).   Despite my grumblings and pointing out the obvious, still loving it!
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
Productive Sunday!
Finished the oars, mast, gaff and boom.
Laid out the sail and treated it with a PVA/water wash.
and stepped the mast!
She is coming along.   Expect to receive my new nails later this week and will see if we can get most of this finished up next weekend.
Edited by Scott Crouse
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
Progress continues.
Received my .7mm nails, surprise!   They fit :).
Got the rear line ready to go;
and the highlight of the day, the sail is drying and will be ready for tomorrow;
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
It’s looking good Scott! The pram was my second boat to build, and I can relate to every obstacle you’ve hit:-)
My first day doing sails and rigging - I have zero clue of I did this right.   The description in the manual is like "huh".   But between the builds on this forum, the manual and the one decent video on youtube, we muddled along :)
Have to say, I am a bit confused by the battens, every small sailing vessel I have been on, the battens are usually in a cloth sleeve, not glued or attached to the sails.   Anyone have insight on if this is actually correct or just simplified for the model?
Lots of muddling with knots and glue.  Probably not overly correct but doesn't look terrible.
Still have the lines to clean up, some paint touch ups here and there and the stand to finish.   So another day or two and will have it ship shape.
Did discover one very serious error today, and I am shocked that no one else noticed it either..... I have been around sail boats for over 40  years and I can't believe I did it nor did not notice it until today.  Scroll up in the old photos and check out the cleats, I glued both of them on upside down bwahahahaha.
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
And we are complete.   This kit was a ton of fun, my 2nd build.  Most definitely there are errors, I know where many of them are and I know how not to repeat them the next time :)   There are things I would do different next time.   Thank you for the encouragement folks!    Onto the Lobster Smack and the Norden 603.1.thumb.jpg.827f195d0a1073665816bfc0e9895c37.jpg2.thumb.jpg.3a5175989d188a391896a2c1c5913e0e.jpg3.thumb.jpg.569b7521bc207c95a60408a15552ae99.jpg4.thumb.jpg.7f66979c129d1002cc349308a68ed5c4.jpg5.thumb.jpg.99344f9a4d0e3b980e7d249e77c81dc4.jpg6.thumb.jpg.92fe6d27fb031b61f0d32123c66b37c9.jpg
Current Builds
Trumpeter R/N Fiume
        Model Shipways Dory
