I am finishing my build of a Marblehead pond yacht and need some advise on how to paint the hull.  There are three coats of clear epoxy on the wood planks that form it’s hull.  I need recommendations for the type of paint that I should be use on the hull.  Thanks in advance for your feedback!
Is the clear epoxy in an organic solvent?
If so, it may be possible that you could buy a small tube of artist's oil based pigment - a quality fine pigment brand - of the color or colors you favor - and mix your own compatible top coat(s).
Epoxy is two part?  Not sure which of the two would get the pigment - I would guess the thinnest one?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Looking for dry pigment - Amazon has Mica dry pigments advertised as being designed for use in epoxy.
NRG member 50 years
Current:
NMS
Other
At least one Epoxy manufacturer, West System, used to sell pigments formulated to be mixed with their resins. There are of course, pre packaged Epoxy paints.  This is all the realm of full sized yacht finishes but should work for you too.  I believe that Urethane marine paints are also applied as a finish coat atop Epoxies.
Roger
