9 hours ago, cdrusn89 said:
Eric,
Did you notice that there was a difference in the placement of the eyebolts on the mast between the drawing and where the holes were on the provided mast?
I ca't tell for sure but it appears that your mast has holes in the same places as mine (dah) so apparently those are the correct locations but i thought it worth the question.
Yes.  Discrepancies like this have been my biggest frustration with this kit series. I just went with the predrilled holes.  If I remember correctly, as I compared other builds, the predrilled holes seemed to be at a better placement than the plans. The halyard and it’s block were a little tight (which could have been my own doing), but everything else worked out ok.
  - Eric
Thanks Eric - appreciate the speedy response.
Thanks,
Gary
Current Build - Rainbow 1934
Prior Builds:  Lucia A. Simpson (Great Lakes Schooner 1875)
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
  • 1 year later...
