Byrnes table saw - belt tensioning
Go to solution Solved by Some Idea,
Hi All
Is there a way to tension the belt?
I was ripping some planks today at it sounded as if the belt was rattling against the belt guard.  I removed the guard but there was no apparent way to apply more tension to the belt apart from lifting the motor on its hinge point.  As a result I've chocked some wood under the motor and this has solved the problem.
Anyone know a better way?
Thanks
Current build:     HMS Mercury - Scratch
Previous buildsMary Rose - Caldercraft
                                HMB Endeavour - Caldercraft
                                Virginia 1819 - Artesania Latina
  • Solution
Hi
I've also had this issue and changing the belt made no difference either.  I contacted Jim who advised me to place a couple of washers behind the tensioning spring.  It's a little fiddly to do but it works great and is a permanent repair.  It just pushes the motor back that little further which is what is required.
