HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Hi, well, I have the planking on – now the sanding.
I was thinking about using an electric sander.: Bosch ‘mouse’ or my 6” oscillating sander?
Or should I purchase a craft specific sander?
There will be a fair amount of filler… so I’m thinking of using an electric sander first then finish off the sanding by hand.
I think I’ve made all the mistakes a newbie can make and then some! I’m learning…🙂
Take care.
I don't know, how big the model is, but is there so much sanding to do that you need an electric sander?
There is also the risk that the edges of the sandpaper bite into concave sections of the hull.
Sanding blocks and sanding foam-blocks might be a safer option.
