Okay, so after deciding to purchase the Duchess of Kingston by Vanguard Models to be my second build (while continuing to work on my Vanguard Sherbourne), I reflected on my mistakes (that I certainly learn from) and how often they occur and considered how much I just spent on the Duchess and what a more serious mistake might mean, and decided to maybe get some more practice on less expensive models first (well, second, third, and fourth).
I just got the Model Shipways Shipwright Series, which consists of the Lowell Grand Banks Dory, followed by the Norwegian Pram, and then the Muscongus Bay Lobster Smack.
I know these model might be a bit more “old school” than the more modern Vanguard designs. But I figured they’d force me to do something different, mistakes would be on a far cheaper model, and they’d be easier to work on while also doing my Sherbourne. I wanted another model (in this case three small ones) to have something to work on while waiting for glue and paint to dry on my Sherbourne parts (like I am now).
Edited by palmerit
I understand now how the “engineering” of Vanguard models is so different from older school models like this Dory.
Constructing the frames involved gluing a couple of pieces together and gluing them to cross plates. There isn’t a ton of guidance in terms of putting the pieces together and it’s easy for them to get misaligned.
After setting the frames into the building board, I discovered that one was misaligned, had to disassemble and reglue into alignment.
Looks like it's coming along nicely!
Not to be overly critical, but one thing you may want to watch out for is how you're clamping the planks at the ends. Due to the difficulty of clamping there, it's very easy for the planks to end up pressed inward, causing a sort of bottleneck shape that looks off and can make it hard to fit the cap rail.
You’re right. I’m learning how to work with this soft basswood. I loosened them a bit now that the glue has set.
I did end up bending one of the frames pretty bad when I attached the garboard plank because I had clamped it (as opposed to clamping a rubber band).
Thankfully, this softwood can also “bounce back” a bit and if you really wet it down and reshape it (I reshaped the frame element by clamping a couple of flat pieces on either side).
That's great! One of the benefits of working with wood is that it's possible to reshape and repair a lot. I found that bobby pins worked well as clamps, providing enough pressure to hold the wood in place without breaking it.
Got the first couple coats of paints applied. While I have an airbrush, here I used the Model Expo paints that came with the trio of models. I didn’t want to experiment trying to thin it for the airbrush (or search for and order matching Vallejo paints), so I just used a paint brush. I did thin it a good bit with water since it was pretty thick, almost house paint consistency. Better to do a few thin coats than apply one or two thick coats.
I don’t know if it’s the model, me, or both (mostly me I think).
The thwarts (seats) are supposed to slot into the frames, but the boat seems to be too wide in places (especially in the middle).
If the boat was too narrow, I could narrow the boards. The thwarts being too narrow, there is not too much I can do (except recreate the thwarts with new would, which I’m not inclined to do for a boat I just did for some more practice).
Come to think of it, I think when I put the planks on, I didn’t ensure that they were fully touching with frames in a couple places, especially in the middle. Then I had to wet the frames to get them to touch the planks and that widened the boat enough to have the thwarts no longer fit. A small error that’s corrected can impact something later in the build.
It sounds like you've done a good job of figuring out the source of the problem! If you're mainly interested in this build as practice, scratchbuilding some properly-sized thwarts could be a useful skill-building experience.
Nicely done,  Congratulations.   :cheers:
Bob  M
                   WASA
                   USRC Harriet Lane
