It also helps to hide the laminated walnut that the carriages are made out of
Cheers
Craig
Current Build
HMS Indefatigable
Erycina - Vanguard Models
Finished: HM Bomb Vessel Granado - Caldercraft, HMS Pegasus - Victory models, Nisha - Vanguard Models
Just had a fight with the brass sheer rail :(
Softened the brass but there is still a bit too much spring in the metal. Using epoxy resin glue to attach it to the hull/capping rail, but did not hold the rail where is curves round the bow. Possibly I did not leave it clamped long enough to cure fully. Will try again in the morning.
Cheers
Craig
Current Build
HMS Indefatigable
Good luck with the sheer rail Craig, must admit it's not a part I'm looking forward to; I'm sure I have read it's a tricky bit to do.
Mick
Thanks Mick
Looking at Timmo's log I see he used a strip of wood instead to fashion his own profile . I do wonder if that would have been a better option
Cheers
Craig
Current Build
HMS Indefatigable
Yep, reasons why I went with timber were half aesthetics and half because I didn't like the thought of fitting that heavy brass to the right curve and then relying on ithe bond holding it to the timber.
But many others have made it work
Well here goes! Off to the man cave to wrestle with that rail. I need to allow it more cure time. As it is a nice day (dry) I think a visit to Doune Castle is in order - "is that an European or African swallow?"
"Nyee"
Edited by Craigie65
Cheers
Craig
Current Build
HMS Indefatigable
Right second rail is working better than the first. It would seem that I did not heat the first rail enough. The second one is far more malleable. So use the gas cooker not a candle to get it hot enough!
Cheers
Craig
Current Build
HMS Indefatigable
And the moment of truth approaches. Just removed the clamp that was holding the troublesome sheer rail and it's still attached to the hull :)
I guess leaving it for 24 hours to cure fully worked. Hopefully the rail on the port side will not give me the same problem.
Cheers
Craig
Current Build
HMS Indefatigable
One down , one to go....hope the second rail goes on smoothly for you.
Mick
Second rail gave me no trouble at all. Trick is to heat it enough to make it malleable but not melt the metal!
Both rails are now own. I'll try and get some photos on this weekend
Cheers
Craig
Current Build
HMS Indefatigable
