i'm about to glue some wooden strips to my uss constitution gun deck,not sure what glue to use.,been told epoxy. would super glue do the same trick, any advice from the mastes would be greatly appreciated.
The gel variant of superglue will work, put a few dollops of glue on the wood and stick it down, you won't have a lot of time to work with while it sets, but you won't have to worry about mixing the epoxy.
A thinner superglue will sink into the wood fibre creating blotches everywhere and hindering its ability to stick properly.
Kits owned: Mamoli Royal Louis, Mamoli Friesland, Mamoli HMS Victory 1:90, Occre Santisima Trinidad, Constructo HMS Prince
I would use epoxy or contact cement.
Cheers!
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Hello,
It's a very good idea to plank the plastic deck with wood. I'm building it myself and I took the same approach. As seen in pictures, I've used super glue. That was happening some two years ago and it's holding them really well.
Be sure though you put the glue only at the bottom side, and just a hair of it, otherwise it will squeeze between the planks fi you push them, as I've used 2.5mm wide strips.
Edited by moflea
Alex.
Current build: Constructo's Union, 1:100 Brigantine
