The USS Constitution kit has four boats that are made up by laminating pre-cut sheets as shown below.
To get rid of the extra wood inside is a bear. I have used chisels, diamond coated bits in a dremmel like tool and then still had to do a lot of hand sanding.post-246-0-29631600-1398201086_thumb.jpg
Some time ago I took an electric toothbrush, cut off the bristles and glued on a piece of sandpaper.
Now I went a step further; took a piece of dowel, adapted it to the electric gismo, flattened one side, added sandpaper and voila . . a nice sander for tight spaces.
Just don't let the kids get hold of it.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Thanks guys, but Mike the drums for the Dremmel are way too course. Keep in mind that the wall thickness for these boats is only about .050 inch.
I do have some other grinding wheels and they may help to 'hog' out the main parts, but not for the finishing.
I have been trying to get some sanding drums for the dremmel with a fine grit, but no luck thus far.
In fact, I have made my own drums for a thickness sander that works on my drill press, but those are larger diameter and not for 'special' usage.
Jud, I remember 'rolling my own' right after WWII. The hardest thing to get was not the tobacco but the papers. My dad even had a little machine that worked like making sushi. Kind of ages me :rolleyes:  :rolleyes:  :rolleyes:
Edited by Modeler12
Jay
The sanding drums come in different grits, so you can use the fine one. Sorry, that's the only picture I managed to google, with a coarse grit :)
But yes, they are to remove most of the material, while the final polish is always manual.
Edited by Mike Y
You apparently missed my whole point of posting this. I don't always polish manually. That is why this little converted toothbrush came in handy for what I was trying to do. Polishing is not necessary because the inside of these boats will be painted.
I would be interested in the little drums in grit sizes down to about 400, but I don't see those any where.
Jay
