snedley22
  1. Hi all, It's been a few years I think, that I have worked on my cut-away model. Life got in the way, but hopefully I can proceed now. I am at a point where I need to "paint, stain, or varnish" the interior boards. The directions suggest using a clear varnish. I have a ton of different paints (browns, tans, old looking), but no varnish. If varnish seems to be the consensus, then what would be a good place to pick up? Hardware store, hobby shop, etc? Not sure what varnish, since there are tons of them.
  2. Thank you sir! I really appreciate it. This will help me out greatly. I don't haveva lathe, but I will figure it out.
  3. Trying to retrofit my OcCre 1:90 Santisima Trinidad cross-section model, with new columns between floors. Need to find possible solutions. 31mm tall, and 4mm dia
  4. Hi again, I had another question. Are you planning on copper hulling this build? Jon
  5. Hi, I am new to site and have just started my build log. I see in your descriptions above that you mention "Hindsight being 20/20 I should have put together the hull, measured, marked and drilled the gun ports and doors, built up to each deck finishing the detail work on it and planking around the gun ports etc then built the next deck up until I was at the top deck." I have cut my gun ports and glued the two halves together so far, so I am at a great place to get some good advice. Are you suggesting that the next step should be starting on the lower level (starting at bottom) and working my way up? I guess I need to know what the specifics or your "detail work" you mean. Thanks. Your project is great BTW Jon
