James78
Members-
Everything posted by James78
Hi. I'm currently building the Bluenose myself and using Bob's practicum. I think you were using it too. I'm soon to be starting the rigging but I notice from the practicum, Bob doesn't do all the lines. I haven't started yet but it's my first ship and I'm trying to get in as much detail as possible. I've been following your build and it's helped me so much with small detail that's hard to make out on the plans. I want to replicate the rigging as much as I can. Bobs practicum has helped me so much but I'm the kind of person who wants as much detail in as I can. Any advice? Your brass bits are amazing. I won't be replicating those like you have but I'm doing my best. Just a little worried about all the rigging to do and that I'll leave out stuff. Not sure if I'm going to ad sails but I at least want the rigging done properly. Thanks in advance.
- 245 replies
- bluenose
- model shipways
Thanks Bob. I appreciate that. Just a couple of questions on what u said. What's different on the plans to the practicum on the painting and deck furniture as I'll be doing those next. I'll look at the plans myself but I just find them so hard to understand from what I've read so far. And on the scuppers... Bob didn't do them himself. I tried to do them but the holes never looked the same if u get me. Very hard to get them all even. I even tried making them bigger but when drilling from the inside out, some of the filler kept breaking off and make them look even worse so I just filled them in and painted the bulwarks white as u can see. What wat did u do them?
Few more progress pics. Painting the false timbers and waterways was straight forward. Adding the caprail at the stern was grand but the two small bits of wood under it didn't fit properly so I had to redo some of that piece of wood as you can see in the pictures. The rest of the rails were fine. Just need to sand the stern a bit before I start painting the hull.
It is rock hard but the hull turned out nice. I'd use it again as I found sanding it with 80grit did the job. Products like Elmers and minwax only to be got in the states which is a balls but I'm sure other products do much the same job. It is my first ship kit so it's all a learning curve for me. Got great support from this forum so thanks everyone 👍👍
Thanks very much lads. I think I just over think things. I was the same with the planking. I ended up doing a good job in the end. I think I'll just go with the shellac to seal it and prime and paint it then. Not used to painting at all. If I'm to do several light coats, what grit sandpaper will I do between coats? Thanks again.
Thanks for your reply. I was advised to seal it with poly. Got myself in a twist then looking up different sealers and using acrylic over poly. Everyone seems to be right but no two answers are the same so I just got confused. The paint I'm using or thinking of using is the paint I got from model shipways. I bought the paint set to suit the bluenose.
Guys just on the polyurethane. I can't get it in Ireland. The states seem to be the only place and it's expensive. I've seen videos of lads making their own with polyurethane and spirits. Went tí my local hardware and all they have is polyurethane varnish. Is this the same thing as just polyurethane? And why do people use this or other stuff to seal the hull? Can I not just sand it and prime it and then paint it? First timer so sry for all the questions. I just don't want to mess the paint job up.
Thanks wefalck. I havnt done anything yet. I got a white primer with the paints. I have the hull really smooth and ready for painting when the time comes. I was just told to put a coat of polyurethane on it first to seal it before painting. Is it needed or will an acrylic primer do? I just don't want to mess it up.
Thank you both for your replies. It's my first ship to build and I've no clue about using polyurethane. I'll get some poly and mix it myself so. Just on the deck as I'm finished it too, does the poly give a nice stain or is there a load of different shades? And a bit of advice on sanding between coats please. I'm building the bluenose. I have a build log up on this site. Thanks again.
Hi. I've finished planking a Hull and I've put wood filler on it and sanded it down to a smooth finish. Just not sure about sealing it before painting. Was told to use an oil based polyurethane. Don't know much about painting, so do I just use a poly varnish? Can't get wipeon poly anywhere. It'll be painted later with acrylic paint. Any help appreciated.
Thanks guys. Yorky you should look up lauck street shipyard and have a chat to Bob through email. Seen as it's your first time too, I'd strongly advise you to maybe buy his practicum. They're well worth the money. By all means do it by yourself either, but he does simplify things so much better which makes it alot easier to do. Don't know why manufacturers can't just give simple instructions and drawings instead of plans full to the neck with small sketches on top of one another! Maybe I'll understand more when I've one build under my belt. Here's a few of the aft deck I'm currently working on. It's a bit tougher with all the tapering involved.
Hi guys. I put a post up a few months ago looking for advice on what my first model ship should be. After doing some research and coming across Lauck street shipyard and chatting to Bob Hunt, I decided to go with the bluenose. Reason for this is after chatting with Bob and him explaining about his practicums, I couldn't pass up this opportunity as I failed at building a ship years ago and didn't want to go through that again! I bought his beginners course which is fantastic. I've a long way to go yet, but his instructions and photos are so much easier to follow than the kits instructions, which I think are so damn hard for any beginner to comprehend. Model expo do say "previous experience helpful" or something like that. To me, that's an understatement. If it wasn't for bobs course, I don't think I could even attempt to do it. I'm sure there are people here who have built it just by the kits instructions and fair play to you, but me being a first timer, I find them very hard to understand. I did build 2 other kits from expo, the Constoga Wagon which was a lovely build and the Wright Flyer which was very challenging, but lovely when finished. Anyway, I'll put up photos of my progress so far. I did make a mistake with the planking. I didn't taper the planks at the bow which meant my planks bowed alot in the middle and the gap at the bow closed alot quicker the the middle and stern which meant me closing the gap with bits and pieces of wood. I showed Bob and he explained about the tapering and advised me to take the planks off and redo it, because there was an unnatural bend in the planks and even though the hull was being painted, he said over time the planks might lift off the bulkheads due to the forse they were under. So I reordered more planks from expo, which I was delighted with them for sending me them and I replanked the hull. Well most of it. You'll see the difference in the colour of the planks where I redone them. I was able to run all the planks the full length of the hull. I have a build log in bobs site but it's for paying customers only. So I said I'd post here as well and see what others think. Here's my progress so far. Sry for the long text. My photos didn't come up in order as I posted them so apologies for that. Not sure if I can put them in order. If I can, can someone please advise. Thanks.
