Elder Jim
Everything posted by Elder Jim
  1. Vintageone,   I saw your request for info on a boat model by the Ferris Model Boat Co posted a couple of days ago, but was traveling and couldn't get back to you then; when I tried to respond the message had apparently been moved or removed.
    Anyway, I can't help with the Ferris Model Co, but my father had a boat very similar to what you described from the early 30's through about 1946.  The boat was called a "Rumson Bay Knockabout"; she was a gaff rigged centerboard sloop, about 22'- 24' long, and rather wide for her length, but she was fast and won his Yacht Club's annual trophy several times.  I was very young at the time so my detail memory is lacking, but if you decide to  build the model, I have several photos of it that I could scan and send to you should you want them.
    Elder Jim
    jcamsr@gmail.com
    1. vintageone
      vintageone
      Hi Jim,That is so neat,I would love to see pics. Thanks,Dave
  2. If this is a first wooden model ship build, I THINK you are setting yourself up for frustration and eventual discouragement in starting out with either the Constitution or Surprise. They are bigger which helps in learning the more difficult construction techniques, but very complex and the amount of work, the planking, rigging, detailing and time required is so extensive that it may overwhelm you. My first model was the Bluenose II by Billings Boats. It is a plank on bulkhead and pretty good starter kit; you will learn planking, steaming, what adhesives work best for you and for what purpose, and don't grab a bottle of super glue thinking it is all purpose, it isn't! My suggestion would be to use something like Tightbond's Woodworkers Glue (the yellowish stuff); Elmer's makes it too--I think they call it Carpenter's Glue. Even though the ship is fore-and-aft rigged, you will also learn rigging techniques and tying ratlines. Alternatively, I would also recommend a Model Shipway's Kit because their instructions seem to be better than most other kits, and yes, I know the Bluenose II isn't one of theirs. When that is finished, you will have a nice looking model that you can be proud of and will probably know if you have the stick too it patience and stamina for a larger very complex model. One final suggestion, don't get a first model that requires you to build up the keel and frames; positioning is critical, and you will need experience to do it right; do overs are frustrating, and if you cut some ribs incorrectly, you will not notice until the frame is finished. They probably won't be fixable so have to be removed, remade and possibly re-positioned in a place that has little room for fingers. My kit came through with the fore and aft keel piece warped, but two pieces of 1/2" 90-degree angle metal from an old Erector set bolted together on each side of the bulkhead solved that quickly and permanently. Good luck!
  3. Iondriver, I have only built one Billings kit, Bluenose II, that I modified to look more like the original ship, and I wasn't too impressed with the wood. If the new wood you need is for hull planking, I would definately use soft woods, even pine would do, as they are much more flexible than hardwoods and much easier to steam for the radical bends an alternative would be Basswood. My Emma C. Berry (Model Shipways) Instruction Manual also recommends Lime wood (Tilia vulgaris) which they say is an European wood which might be easier for you to get, and they say that Lime wood has superior steam bending qualities. They note that it is often called Basswood in Europe. As an experiment some years ago, I tried restore dried out wood by lightly moisting a paper towel, wrapping it around the wood (don't stack the planks), then wrap in waxed paper and weight or clamp down onto a flat smooth surface. After a couple of days remove the papers but leave the wood clamped down until it dries. The process restored the wood, but much of it warped; it wasn't worth the effort. Good luck with your building project.
  4. For a first build, I would strongly suggest brushing. "Spraying", I assume you mean air-brushing, is somewhat difficult, and is a technique only aquired with lots of practice. Why risk messing up a first model with a newly learned technique? You wlll already have several learning curves to conquer. I understand what you want to accomplish with the different colors highlighting different parts, but I'm not sure it will enhance your finished product, and take to heart Testazyk's caution of glues over paint; it doesn't work well. Eventually the paint will age and flake off; your repair job is then much more complicated unless, of course, it will be the next generation's problem ! Good luck your first project--don't rush and get frustrated; you picked a kit company that generally provides the best instructions for kits in that price range.
  5. If the Admiral ain't happy, nobody's HAPPY! After 50+ years of being married to the same woman this advice is from well earned experience: (1) If the Admiral ain't happy, nobody's happy, (2) Flowers work and if you add dinner at a new and good resteraunt, it works even better, and (3) Never-Ever refer to the reason for your new purchase as "because she bought a new .......".
  6. Floyd, If an aging memory serves me correctly, the first nuclear surface ship was an experimental cargo vessel; I think it was the USNS Savannah, but she was too expensive to operate. After afew years, she was taken out of service and layed up in Charleston, SC for years; I think she too was finally scapped. Too bad she was a pretty boat. Jim
  7. Bill, It is undoubtedly accurate, but in the scale at which we are generally working and the time involved, is it necessary? A friend showed me a semi-quick way to make them. He used a thin, blackened copper wire cut perhaps 1/2" longer than the ratline width at the point you are working; crimp one end around one outside stay, do a 360 degree wrap around the middle stay & crimp lightly, make a 180 degree wrap around the other outside stay, cut off the excess wire and crimp---Done! With a bit of care and practice the ratline will be straight and level; if you want some sag, put it in before the middle and last wrap. They will never come untied . At our small scales, you won't be able to see that it isn't tied, at least not from a normal viewing distance. Jim
  8. Tripp, I have the Emma C Berry partially completed but delayed for several reasons;I will get back to it. It is a POF build, which I guess I did not realize, and the building of the frames and putting them on the false keel is tedious, rather delicate and needs to be very precise. I am not disappointed with the kit; the instructions and quality of the wood are very good, but it is more work than I expected. I think I paid about US $80.00.
