Firstly - Apologies if my nautical parlance is not up to scratch but this ship modelling is a steep learning curve.
	HM Schooner Pickle is my second pob build, and I have decided to post a build log for a couple of reasons:
	Looking through MSW as a first timer was a constant source of help and ideas, the Build logs, downloadable files, and topics on the help forum got me past many hiccoughs (& mistakes on my behalf) and got me to the end of HM Cutter Sherbourne with a model that, though I constantly wish I had done "that" different etc, I am proud of.
	Secondly it has been mentioned by many people that lots of content has been lost since the "great crash" so hopefully my contribution could help fill the void - and though I am still very much a beginner, I will be  pointing out things that I do differently this time around - possibly helping other starters.
	HM Schooner Pickle
	On recieving the long awaited parcel (3 whole days) I curbed my instinct to get "stuck in" ,and as well as the obligatory examination of all the wonders enclosed (Brass turned carronades, copper plates et,al) I took the time to completely read the two manuals (far better than those included with Sherbourne)and look over the plans thoroughly. So far so good no unpleasant surprises.
	First things first, I removed and cleaned up the edges of all nine frames & the Keel, and dry fitted them - no problems there. Next step was to taper the keel from the bearding line to the stern, this was surprisingly easy to do with a chisel bladed hobby knife and sandpaper, continuously checking the measurements with a vernier - this is also not something mentioned in the Sherbourne manuals and plans and would make a world of difference.
	 The next step is hopefully where I will simplify my efforts compared with Sherbourne: Being a newcomer I did not understand the importance of bevelling the bulkheads to follow the curve of the hull. The result was a first planked hull that needed  at least 4 hours with sandpaper and about  2lb's of filler, and even then the second planking was difficult due to very flimsy sections to attach to. Perseverance, and initial enthusiasm was all that got the second planking completed. With this in mind I am starting with a trick I believe will help (I am not sure after so many hours on the internet where this one was from, but whoever you were THANKS in advance) The idea is quite simple (once someone else has had it); to get a strong smooth first planking the bulkheads need to be bevelled to continue the shape of the hull, and give the greatest surface area to glue to, but the furthest outside point of the bulkhead needs to be kept to keep the hull lines correct. The idea is that you colour the edges of the bulkhead with something such as a black permanent marker, then start bevelling the bulkheads as per the kits instructions - or the guides on msw - but allways leaving some black showing from top to bottom on each bulkhead. I will let you all know how this went for me after the weekend - the boss requires heavy sanding to be done outside and it's rain till sunday!!
	Skippy
