argyris_
375 profile views
  1. Thanks Agryss - the others are the parts for the small cranked winches by the deadeyes. Apart from the copper plates, I did find myself short of 6mm dowel. According to my calculations, they did not supply quite enough for all the masts and spars defined as 6mm. Haven't got to the chain yet, but I suspect David is correct and it will be short!
  2. Hello Charles, the ones on the right are shown in the Fig.51 (mast related), but I haven't found the other parts though. I'm quite behind from those steps. still coppering and found that there copper plates aren't enough. what other shortage have you found? apart from the insufficient chain that David had mentioned in previous post. just to be prepared! thanks, Argyris
