Everything posted by KeithAug
Hello Mark I agree it was a bit scary - I imagined the auger drifting off sideways down the hull leaving a nasty scrape on the planks. Luck however was on my side. Hi John - thanks for the feedback. Keith
Having completed and finish sanded 1st planking I had a few things to sort out about future stages. After some thought I decided on the following sequence:- 1 Drill the hole to take the prop shaft. 2 Mark the waterline. I wanted to compete items 1 and 2 while the hull was still attached to the building board - so that I had a reference datum for the 2 operations. The sequence continues with:- 3 Remove the hull from the building board. 4 Trim the frames to size at deck level. 5 Mount the 1/16th inch ply sub deck, with cut outs for the deck house, skylights and hatches. 6 Plank and finish sand the deck. 7 Mount the 3 layers of 1/32 inch ply which form the bulwarks and the sculpturing of the hull sides. 8 2nd plank the hull. (Having manufactured the planks from mahogany). This lot should take care of the next few months. Staring with the prop shaft which is asymmetric - sitting on the port side of the hull. The prop tube is 3/8 inch diameter, angles downwards at an angle of 6 deg and outward from the centre line at an angle of 8.5 degrees. See Photo. I didn't feel comfortable trying to drill this by eye, so I manufactured a simple jig consisting of 2 parallel MDF boards, separated by 3 inch, drilled with offset holes the alignment of which gave the compound angle necessary for drilling. I did have to revert to a bit of school room trigonometry which taxed the brain cells more than I expected (a bit worrying). See Photo. Having positioned the jig so that the drill intersected the hull at the correct point I then clamped it in place and drilled the hull with a 3/8 inch by 18 inch long auger drill. To keep things under control I took my time and hand drilled using a woodworking brace. The photographs illustrate the procedure.
I have now completed the 1st planking on both sides of the hull - so far so good. Although I had thought that I would revert to narrower planks at some stage, in the end I found it to be unnecessary. Before sanding I roughly drew pencil lines on the hull to act a sanding guide. Sanding to remove the pencil lines enables me to achieve a smooth finish while avoiding sanding through of the planks. I have completed the sanding of one side - it took about an hour and a half using coarse grit emery cloth on a cork block. The bow and stern shots show the before and after. I have abandoned sanding - family are arriving soon and they plan to stay for at least a week. Boat building has to be curtailed for some time.
Hi Pete, John and HArtmut. Thanks for your encouragement on my planking efforts. Its time for a progress update. I thought I would get the difficult bit out of the way and continue with the tapered planks around the hulls belly. The photos are fairly self explanatory so I'll cut down on dialogue. The final closure plank is always the most tricky to get right and I have developed the "black finger method" to make it easier. I start by loosely laying a piece of printer paper over the hole to be filled. Running a finger over the paper above the hole creates an indent which accurately represents the shape of the closure plank. I find it really hard to see the profile of the plank once the paper is removed so I shave some graphite from pencil and rub my finger in it. I then rub my finger over the paper and this gives me a very visible profile for the closure plank. I then cut out the profile to make a template. The template is transferred to a plank and glued in place using a glue stick. The plank is cut out, finish sanded to fit and then glued in place. Now I can proceed with the easier task of planking the keel.
Hi Pete - thanks for the positive feedback. 1st Planking the hull continues. After completing 9 parallel planks the curvature was getting a little excessive so it was time for a change in strategy. I started looking for a natural plank line and then dithered for hours wondering which line would be best. After drawing many options on the hull I decided to be undecided and just ploughed on regardless - reasoning that I'd make the best of whatever line I chose. I marked a line using a stiff plank and used pins to form location points for positioning the first of the next stage of planks. Having marked out the plank line on one side of the hull I used dividers to transpose an identical line on the other side of the hull. So far the planking on either side of the hull is identical and I want to keep it this way - silly really as it will be over planked. (My OCD kicking in again). I have now completed 3 of the new phase of planking and all is well - so far!!!
Hello Nils Good to hear from you again. The lines are nice which eases planking. Getting the bulwarks right is probably the key to producing a good model - but that is some time away.
How would you improve your Byrnes tools?
KeithAug replied to Keith_W's topic in Modeling tools and Workshop Equipment
Hi Richard Have you used this email address <jdm@cfl.rr.com>. It's the one used to notify me of my shipment and I have used it successfully to contact Jim. Keith -
The deck (and hence the hull top line) has a significant bow from stem to stern. I therefore decided not to try and follow the deck to hull intersection with the 1st plank. Also the first plank was being laid at a small distance from the hull / deck intersection to take the later installation of the bulwark. The line of the 1st plank was marked using a flexible straight edge which I made from .060 inch plastic. Having marked the line I placed a number of pins along it to act as stops against which to accurately locate the 1st plank. The first plank was then installed using PVA wood glue and held in place by notice board pins while drying. At .060 inch thick the first plank wasn't as flexible as I would have liked and so I decided to thin down succeeding planks progressively thinning each plank by .002 inch (reducing the planking thickness .050 inch by the 6th plank). Another departure from a previous post is that I found that I only had .250 inch x 3 inch x 48 inch obechi. I ordered up some .200 inch but decided to progress the planking using what I had. I will revert to the narrower planks where the hull curvature becomes more pronounced. The first 5 rows of planking have gone on well and I haven't felt the need to do any tapering thus far. The natural flow of the 1st plank left the stern in need of additional planks and before proceeding with the stern I marked a straight edge for the uppermost (nearest the deck) plank. I checked that the line for the upper plank was identical on both sided of the hull using my improvised height gauge (on the right of the picture) I then installed the top plank on each side. I then infilled the remainder of the stern using tapered planks.
I have covered this elsewhere - but it also fit with this topic. Self adjusting side pressure to push wood against fence. As an alternative to a feather board. It works very well and eliminates much of the resetting necessary with a conventional feather board. -
Experiments with Planks. For a while I have been thinking about planking the hull. In particular I have been considering how to go about creating the sculptured lines on the bulwarks. See Photo I think I am going to overlay 3 layers of 1/32 (.031) inch ply to create the effect and this means the planking thickness will need to total 3/32 (.094) inch (to avoid a step where the ply meets the planks). The outer mahogany planking on Endeavour was .020 inch thick by .160 inch wide - basically a veneer. It had the advantage of shaping easily but I was very nervous that I would rub through when finish sanding. In the event I din't rub through but I can't help thinking I was lucky. For Altair I thought I needed to go thicker. Mulling things over I decided to 1st plank with bass or obechi planks .060 inch thick and .200 inch wide and 2nd plank in mahogany .031 inch thick and .200 inch wide. The challenge of accurately cutting the mahogany second planks (which I haven't done before) prompted a bit of experimentation. The mahogany I am using is about 100 years old, beautiful stuff but a bit brittle. I ripped the 1 inch thick plank down to .200 inch thick using the carbide blade supplied with my Byrnes saw. I then switched to a 1/32 (.031) slitting saw blade to cut the .031 inch thick planks. The set up of my saw (which is a bit unusual) is covered in the attached series of photos. The experiment was a success. I cut 3 test planks and all were .031 +/- .001 inch. I am now feeling confident about going into mass production.
I thought it would be interesting to compare the hull with what Endeavour looked like at this stage. I have done a better job with balsa backing Altair. Endeavours frames however show the greater uniformity of shape. Laser cutting of frames on a mass produced kit clearly has advantages over not so well drawn jigsaw cut frames.
Much sanding - but now complete. It took about half a day per side using 60 grit emery cloth attached to my home made sanding block - in one of the pictures. The reshaping of some of the frames (mentioned earlier) proved to be necessary. Marking the edges of the frames was very helpful as a sanding guide and the sanded hull passed the "hand undulation check". The frames in the area of the hull at the top of the rudder proved to be incorrectly shaped and i will sort this out prior to 1st planking. I have attached a photo of the real thing to show what I need to reproduce.
I tend to find the slight taper on the back of the fence is insufficient when I am cutting thin planks. I know that some recommend locking the front of the fence and then pushing over the rear to increase the clearance. I prefer not to strain the fence. What I use is a .020 thick 6 inch rule which I attach to the fence using double sided tape. The inner end of the rule is position 1/4 inch behind the front of the blade. It works a treat. -
I find that the plank tends to ride up at the back when I am cutting thin planks for hull planking. It can be avoided but I decided to make sure by adding a device to hold down the back of the plank. It adjusts easily for height and horizontal position. -
Again stuff i have posted previously - copied here as it seems to fit. 2 devices for storing accessories - so they don't go walkabouts. -
Hi Danny, Like you i found blade changing quite a frustrating process. My mod makes it really easy. Keith -
Hi Guys I have posted this stuff on the Jim Byrnes model machines thread - i repeat her as it also fits in with this topic. Shaft lock to make blade changing easier:- -
Proxxon TG125 Bench Disk Sander
KeithAug replied to pompey2's topic in Modeling tools and Workshop Equipment
Hi Nick Here is another cheaper option. I bought this from Warco although other suppliers sell the same machine:- BDS 130 Belt & Disc Sander It costs £69. If you don't want the belt a cheaper version without it is available. The belt does make it quite noisy. The mitre gauge / table was very rough and ready and not very accurate so I machined up the surface and widened the slot to take the mitre gauge off my Byrnes table saw. The result is a perfectly adequate and accurate disc sander. Here is my sander as modified. -
Balsa Infill Prior to Planking I find infilling between frames with balsa eases the planking operation. Also I quite enjoy the process as it’s a bit of a challenge creating the 3 dimensional shapes necessary to nest between frames while conforming to the profile of adjacent infill pieces. All the balsa is ½ inch plank 3 inches wide by 18 inches long. I needed 12 planks to complete the hull – cost me £12 on ebay. I use a disc sander for shaping – mine has been modified to take the miter gauge from my Byrnes saw. A simple and cheap way of getting an acceptably accurate disc sander. Having completed the rough fairing of the frames I re-marked the edges of the frames with the felt tip pen. This would give me the guide for final sanding once the balsa infill was complete. I find filling alternate frame gaps with balsa has the benefit of allowing me to progress while the previously completed and glued balsa infill dries (I use a PVA wood glue). Also at this stage I roughly shape the infill using a rasp leaving about 1/16 inch of balsa proud of the adjacent frames – for final finishing with sandpaper. I then infill the remaining frame gaps before finishing the rough shaping with the rasp.
Michael / John The lines are looking good - nice rounded form, not a sleek racer but nice never the less. I need to think about what's next. I filled between the frames with balsa on my last model and then double planked and it worked so well I think I might repeat it again although I may just single plank. Decisions decisions!! Keith
Frame Adjustment & Fairing Having done the test assembly I did the usual plank check by laying a .040” by .200” plank along the length of the hull and looking for high and low spots. The significantly oversized frames were marked with a green felt tip and the significantly undersized frames were marked in pink. By significant I mean a deviation of between .040 and .080 inches. See Photos. The oversized frames were easily adjusted using disc sander while the undersized frames had to be built up by bending and gluing .040 strips of wood around the frame edges. Having got the frames about right I then glued up the skeleton of the yacht. Only 4 of the frames were glued to the building board to ease removal at a later date. Because all frames were positively located in building board the gluing of 4 frames proved sufficient to create a very rigid assembly. After gluing I used a felt tip pen to colour the edges of all the frames. I do this as I find it gives a very good guide when sanding to fair the frames. By watching where the felt pen is removed during sanding I am able to duplicated the fairing on both sides of the hull and ensure that that the blending of the hull lines is uniform. I take my time while sanding and frequently check the form of the hull using the previously mentioned flexible plank. See photos.
Thanks Pete. A few of the frames require some work as the plans seem to be less accurate than ideally I would like. Fortunately I think i will be able to sort them out. Keith
Keel and building board A bit more progress fitted in around various DIY jobs. I transferred the keel shape to card that I the stuck to the ¼ inch ply before more jigsaw work. See Photos. I made the building board from ¾ inch thick 6 inch wide MDF. For about 2/3 of the length of the hull the building board is double thickness with the stand off for the frames reduced in height to compensate (reducing plywood wastage). Using my router table I machined slots along the length of the MDF to facilitate:- 1. accurate alignment of the 2 boards 2. location of the frames along the center line 3. location of the board on the milling machine to cut slots for the frames at right angles to the center line. The frame spacing was accurately measured from the plan and I used the digital read out on the mill to accurately set the positions for the frame sots. None of the frames were equally spaced which was a bit of a bind. The photos should illustrate the process. Finally I did a test assembly of the frames to give myself a feeling of progress. Everything fitting together well and all right angles accurately made .......... feeling very content!
Frames finished (23 in all) Having cut out the frames I stacked them and did an eyeball check on how well they nested. All seemed to be sensible with the exception of frame 8 which was noticeably too narrow by about 3/16 of an inch. I assumed that I had marked it out incorrectly so rechecked it against the plans. It turned out that I had marked it out correctly and the frame drawn on the plan was incorrect. The frames on the plan are all individually drawn rather than the normal convention of overlaying all hull lines on a single image. The latter approach would of course have revealed the error during the draughting of the plans. I corrected the problem by widening frame 8 with strips of wood on either edge and then sanded by eye using frames 7 and 9 as guides. See Photo. I used the jigsaw to cut through about 80% of each frame at deck level to ease removal of the building board up-stand later in the build. I then stacked all frames to satisfy myself that the transitions between frames seemed logical.
A dilemma for the future? Bulwarks extend above deck on all sides. So the dilemma is do I do the deck and deck planking before the hull planking. The advantage of this sequence is that I get unrestricted access for fitting the sub deck and sanding the deck planks. The building notes suggest hull planking first!!! All this is made a bit more complicated by the sculpturing of the upper section of the hull. See Photo. Hello Michael - my jigsaw work is flattered by my camera, its ok but not as good as I would like. I really need to bite the bullet and buy a scroll saw. However I have so many saws and I'm worried that my wife will think I am developing a saw fetish.
