Lee J H
Everything posted by Lee J H
  1. hello. I also gave up on making this kit. I'm glad you made this because I think it will be of great help to me. HAPPY New Years.
  2. Although the result is not as good as the brass wire, the result was satisfactory in its own way.
  3. After sanding it with 220 sandpaper, I sanded and nailed the wood. Printer ink was used as the dyeing material.
  4. I made a Carrige on the Gun Deck. These are hidden by the Main Deck and are not visible, so I made it simple. I also made a door frame and attached it.
  5. The bag included in the kit was wide, so after cutting it in half, I sanded it down with sandpaper to shorten the width a bit.
  6. I was conflicted with one more thing. This lowest part, the Gun Deck, is a place that cannot be seen unless the lattice window of the Main Deck is opened. Reserve space for the Bowsprit in advance.
  7. Remove the traces of bond on the side of the hull and perform reinforcement work.
  8. It was sanded. Sandpaper No. 100 to 150. If there is another process of using adhesive above, it seems to be a bit slippery if sanded finely, so always finish sanding the first flanking surface at 150 grit.
  9. The planking material of this kit is 1.5mm thick. It is thinner than 2mm, so it is easier to handle than 1.5mm, but if there are many steps, the probability of holes increases when sanding. After the first planking, sanding and gunfire work remained.
  10. Spring is coming in Korea. The daily temperature difference between morning and evening is more than 15 degrees. Clean up the side of the ribs. Where it's lacking, you have to cover it up and grind it.
  11. Is it carved from boxwood wood? I am so envious of the smooth work results
  12. The space between the ribs was stuffed with balsa wood. Although this process is cumbersome, it is a good job for the overall line.
