elainedouglas
1,152 profile views
  1. Thank you for the kind words Gary. Now let me think of a way to add another block and make the shape. Regards, Douglas
  2. Hi Gray ! I love you so much ! Finally there is one telling me whether I am doing right or wrong. It is my first time and I found it very difficult to visualize the shape of the bow and stern. Now you are telling me what it should be like. I am glad that you are telling me at this early stage. I got to figure out what to do to make it right. Looks I got away to another modelling project is to wait for your comment ! Thank you again ! Regards, Douglas
  3. Was away from the Confederacy and had my hands on an Italeri 1/48 ES-3A and a Gundam model. Now back on this project. Hope to post a little progress soon.
  4. Moving onto the beakhead bulkhead deck. Basswood strips were planked. It was said that the top of the planked deck should flush with the door opening sill. It was already a little lower than the sill. After sanding, it is even lower. May be I have to plank a second layer and make it good. Should I sand the deck to a curve shape ? Lower at both sides and higher at center ?
  5. Bulkhead No.3, somewhere is undersized. It was discovered during faring process. A thin strip was added and sanded to shape.
  6. Got the wood filler and tried it out at the simulated bolts at keel scarf joint. Looks quite light in color. May be staining would make it looks better.
  7. Hi Martin, yes, I am still here. I tried to make perfect the bow and stern filler blocks, well, I tried to make it better. Then I went for a family tour, and then to arrange shipment of a R/C model boat from Bristol.............haha, these were what made me busy and seemed to be disappear. I am still here and I will get back onto the model, soon. Regards, Douglas
  8. This is my first time building a wooden ship. I found it difficult to visualize the shape of the stern so I think I better do a stern filler. Here is the pair. What do you guys think ? Are they look right ? They are not yet attached onto the frame.
  9. I am not too sure about how curve the stern should be, so I transferred the drawing and cut a card board to check. I did it too curve and I made a correction.
