Everything posted by felix nadeau
Questions about Artesania Latina HMS BOUNTY
felix nadeau replied to felix nadeau's topic in Wood ship model kits
Bonjour à tous, la moitié du pont est fait, dois je mettre des faux clous ( pointe de compas et pointe de crayon hb ) clouer en diagonale sur les couples et face à face sur les joints de planches Hello everyone, half of the bridge is done, do I have to put false nails (compass tip and hb pencil tip) nail diagonally on the torques and face to face on the board joints
Hello, I'm at my second project after the Bluenose, I'm attacking the Bounty
If you have any advice, I'll take everything that helps me progress
If someone is to build the same, I would like him to advise me if there are any mistakes or things to share with me
P.s. My friend Pierre is also doing it 200 km from my house, we will share our knowledge to make this model
Hi Felix, welcome to MSW. When you start a build log, click on “ create” at the top of the page. In the drop down menu you will see “ Status “ and “Topic” . Choose Topic instead of Status. Then select Forum. Choose Build logs for ship model kits by era. In this case you wil choose Kit build logs for subjects built from 1751- 1800. Then give your build log a title. Name of Ship/ Your Name/ Kit Manufacturer/ Scale. When you use Status to make a post any replies you receive will not bump your post to the top of the page. Good luck with your Bounty.
Thank you all, I will try to translate my comments and questions, if there are manufacturers who are doing it now or we have already done it, I am open to any comment and stuff that could help me Here is the support kit for the construction and I will place my keel to be able to align the pairs, to my question of the torque # 4, I put the laser and it confirms to me that it must be lowered to the maximum and sand it later if necessary, then sand the brown cut of the laser Thanks -
Here's already a question? The first pair (piece # 4) exceeds the keel about 5 mm, do I have to sand it to be equal? If I climb it, the bridge will be higher in this place! What is the best support for the keel and ensure that couples are in their right? -
Thanks guy , my English is not very well -
Voici que déjà une question ? le premier couple ( pièce # 4 ) dépasse la quille environ 5 mm , dois je la sabler pour être égale ? Si je la monte, le pont sera plus haut à cette endroit ! quel est le meilleur support pour la quille et s’assurer que les couples sont bien droit ? -
Bonjour, j’en suis à faire mon deuxième projet après celui du BLUENOSE d’artasania latina, voici qu’avec mon ami Pierre, nous commençons tous les deux à distance, moi à BOIS-DES-FILION (Québec, Canada) et lui Granby (Québec Canada ) nous aurons besoins d’aide et de conseils pour réaliser : LE HMS BOUNTY d’Artasania Latina esperant recevoir vos judicieux conseils !
