Timothy Wood
Everything posted by Timothy Wood
  1. Greetings, I happy to say the BlueJacket 80' ELCO PT Boat is finally finished after a little over two years! Cheers, Tim
  2. Happy New Year to everyone! It's been six months since my last post and I have not been at the bench as much as I would have liked, but thats life. Here is a current photo of the 80' ELCO. I must say she's very close to being completed. Cheers, Tim
  3. Greetings, I did get some work completed on the ELCO this weekend. I've started to install the small deck fittings along with the torpedo tube turntables. Below is a photo of some of the bow deck mountings, the other to shots of the boat are with the assembled parts setting loose on the deck. Cheers, Tim
  4. Greetings, Once again, I've stent too much time away from the bench so last week I decided to get back to it during a rainy weekend. I got tired of looking at the hull one color so I decided it was time to add the waterline. Cheers, Tim
  5. Greetings, I was able to get some more time in at the bench today which is always a good thing, because the prospect isn't too good this coming week. I finished mounting all the windows, mast, mast supports to the Day Cabin. The yard was glues to the mast along with the cleats on each side at the mast base. The Day Cabin hatch, non-skid, speed wrench and boat hook will be installed after a coat of primer has been applied, which will be at the mercy or the weatherman. I still have to attach the blocks at each end of the yard then thread the flag halyards through each. Cheers, Tim
  6. Greetings, Today was a rainy gloomy day here in Virginia Beach which means it's a good day to hit the building bench. I managed to get the Day Cabin about 80% completed. As you can see, I still have to paint the torpedo tubes. Our weather hasn't been warm enough to get out on the porch for that yet, hopefully in the next week or two. I included a shot with most of the toys placed on the deck just for kicks and a photo op. Cheers, Tim
  7. Greetings, I've been working in the ELCO just over two years now and I can finally see a light at the end of the tunnel. Today I finished work on the four torpedo tubes, they still ned to be painted and the torpedo head mounted in the forward end of the tube but the hard part is finally behind me. The impulse chambers have been mounted along with all the brass photo-etch parts on the tubes, the hardest part was cutting and mounting the rings to the reinforcing plates, (see photos below). Reinforcing rings for torpedo tube still on the tree. Reinforcing ring in first step for sizing to fit the tube, the forward and rear rings are two different sizes. Test fitting reinforcing rings until final size is obtained. Torpedo tube complete with all brass and reinforcing rings attached. Cheers, Tim
  8. I'm leaning in the direction of PT-124. One of my favorite WWII prints was done by an artist named Tom Freeman. He did a superb painting called "Action in the Slot" depicting the Japanese destroyer Makigumo going down at the hands of PT-124 in 1943. My current plans are to purchase a copy of the print and display it with the finished model. This is a copy of the print. Cheers, Tim
  9. My next task was to place the front and rear saddle on a flat surface, set the tube into them, align each saddle with the center of it's reinforcement plate, then glue them to the tube. This step was quite easy! The next step requires a more steady hand and a set of magnifying visors, (at this point I wish I had bought the type with LED lights). Then I snip two front and two rear gussets from the photo-etched sheet and glue them in place on top of the reinforcement plates. (See photos below). There will be four for each tube for a total of sixteen gussets to mount. Cheers, Tim
  10. Greetings, a snowy morning in Virginia Beach makes for a good day at the building bench! I managed to get the Breech Covers, Impulse Chambers, and all the Access Covers on the torpedo tubes and some work on the Day Cabin. Cheers, Tim
  11. It was some scrap that I had after our contractor did some work in the kitchen, figured I may as well use it for the PT Boat. Better than tossing it in the trash bin, after all I paid for it!
  12. ​Note: Comments on messy bench are not allowed! At this point the pieced are placed on deck, nothing has been glued at this time. Three overall progress views: Cheers, Tim
  13. Greetings, Happy New Year to all... I finally made it back to the bench today, thought I would jump ahead to the torpedo tubes for a little fun. The first step was to cut the supplied 7/16" brass tubing into four tubes 5" long using a small miter box and a fine-tooth razor saw. This step didn't sound like very much fun, too many things to go wrong with a miter box cutting a round object. Instead I used small tubing cutter, this was much faster and provided a much cleaner cut. The next step was to draw a center line the length of each tube, the line was used as a reference point for attaching the various pieces to the tubes. This was accomplished by laying each tube on the plans and marking the location of each photo etched part with a mechanical pencil. The reinforcing rings were glued to the tube first the the reinforcement plates were added. The next step was to drill a hole through the through the training gear lug along with a hole into the end of the training gear housing. At a later point a length of .020 brass rod will be inserted through these holes. Cheers, Tim
