philo426
Members-
Everything posted by philo426
I came up with this little gadget to hold the deadeye in proper position while i thread the line through them.
- 93 replies
- swift
- artesania latina
Set the main mast and did some further rigging.
- 93 replies
- swift
- artesania latina
I was considering it.Maybe I should go to Dots and get some cloth for the sails.
- 93 replies
- swift
- artesania latina
I decided to mount up the main mast first due to the long spanker boom.I am glad that I used 5 min epoxy as it allows you to adjust the rake fore and aft.The rigging took a lot of time because I had to be sure to do it according to the plans.The tiny blocks made running the thread through them somewhat difficult.
- 93 replies
- swift
- artesania latina
Mocked up the yard after fitting the brass on.
- 93 replies
- swift
- artesania latina
I used .80 styrene for lower doubling and a piece of sheet brass for the upper.The top mast is warped a bit but it is ok because the mast is raked anyway.
- 93 replies
- swift
- artesania latina
Tapered the foremast with my old Stanley block plane.I then chucked it into the cordless drill and held it against sandpaper.
- 93 replies
- swift
- artesania latina
A little more work.I really like the ogee arch of the bow rail!Even if not correct for the Swift it looks really cool!
- 93 replies
- swift
- artesania latina
Mounted up the fenders and the lower rat line deadeye.
- 93 replies
- swift
- artesania latina
Yes it was effective and the cordless drill is variable speed so it is easy to check your progress as you go.
- 93 replies
- swift
- artesania latina
I had to think of a way to taper down the bowsprit.So I put it in my cordless drill and held a chisel against the rotating bow sprit blank.Then I chucked a coarse sanding drum in my vise and again held it as it rotated. Then I used fine sand paper to smooth it out.
- 93 replies
- swift
- artesania latina
I really like the red dragon head!Looks really fearsome! Is it true it spewed forth fire?
- 51 replies
- turtle ship
- young modeler
Got the door installed and the tiny copper hinges.Funky for sure!
- 93 replies
- swift
- artesania latina
