tomsun
Everything posted by tomsun
  1. Hi druxey thank you, it was my intention from the beginning to build as close to the original with all deck except the trossdeck, and I take photos before I put the next deck in , for me it is the joy of building that counts, it's very relaxing, I've been doing this ship for nearly 17 years with a break for 12 years
  2. I paint the lower counter in a blue colour and then I paint the ribbon with the name on, the two new peaces at the wing transom is in plac I also paint the clinker built bulwarks, and the rudder was made and put temporarily in place
  3. The quarter galleries are been built up and the floor in the quarter galleries is laid, and the frames is in place
  4. The carved peace that go on top of the counter timber called slingerplank is to be mounted, I have made a mistake when I planked the counter earlier I should have waited until now to do that, but no greater harm is done I fix that later, the two carved pieces that vas mounted in wing transom is removed and new will be done
  5. The lower part of the foremast and mainmast is finished and put in place temporarily, the bowsprit is also finished but not mounted
  6. The four scuppers from the lower gun deck is seen between the lover wales and the scuppers from the main pumps more at the rear
  7. Work on the beakhead bulkhead continues and the planks for the beakhead is completed. The planks for the beakhead are made of boxwood and the cants has been marked with a pencil The head gratings and the seats for the crew is finish
  8. Continue to building up the head, the upper head rail with it's carving is in place, and the building of beakhead bulkhead has begun
  9. The Dutch lion in place, the head timbers, lower and middle head rail is mounted. The lion is made of Boxwood
  10. The building of head, upper and lover cheeks is glued and pinned in place. The cheeks are made of Cherry in the middle and two thin layer of Walnut glued together
  11. Riding bitts and the bitts in place By the way as you see in the photos, I am not a good photographer and tha fotos are taken in 2001
  12. The lower gun deck is finished, the pumps, after capstan and mainmast knighthead in place, the hatch and hatch cover is also in place
  13. The wood I used to lay the deck on lower gun deck, Lime wood, was not a god choice, it was to soft, I painted the side and the end of the strips with a marker penn and the ink penetrated the wood, but i dicided that the deck have to stay when nobody could see it after the upper gun deck is in place. JAlbum 4.0
  14. Inner planking finished all the way up and painted red, the deck planks has begun to be laid, the riding bitts is in place and the lower part of the pumps laying on the deck.
  15. The entire lower gun deck beam in place and inner planking up to upper gun deck in place. The beams are made of Beech wood and the inner planking is made of Lime wood.
  16. Hi Albert Just joined this forum and I just looked through your model ship building logs. and I say the same as all the other members what a fantastic work quite outstanding
